你好,
PMOD设置很好。
实际上,当你点击FX3——& GT;SPI Flash时,它会将BooDealver代码下载到FX3中,并用VID -04B4和PID - 4720枚举。看起来它不是自动绑定到驱动程序的。因此,请尝试手动绑定此驱动程序(CysB3.IF位于C:程序文件(x86) CyPress EZ-USB FX3SDK 1.2 驱动 bin Win 7x64)。
您可以通过右键单击设备(设备管理器)并按下“更新驱动程序”来实现这一点。导航到CysB3.IF的位置。
在这样做之后,您可以点击重置并尝试编程SPI闪存(FX3-和GT;SPI闪存)。然后它应该直接向你询问.img文件。
请确保J101到104连接在2和3之间,以便成功地编程SPI闪存。
谢谢,
Sai Krishna。
以上来自于百度翻译
以下为原文
Hi,
PMOD settings are fine.
Actually when you click on FX3-->SPI FLASH then it will download the bootprogrammer code into FX3 and it will enumerate back with VID - 04B4 and PID - 4720. It looks like it is not binding to the driver automatically. So please try binding this driver manually (CyUSB3.inf located in the C:Program Files (x86)CypressEZ-USB FX3 SDK1.2driverbinwin7x64).
You can do this by right clicking on the device (in Device Manager) and press "Update Driver". Navigate to the location of CyUSB3.inf.
After doing this, you can hit reset and try to program the SPI FLASH (FX3-->SPI FLASH). Then it should be directly asking you for the .img file.
Please make sure that J101 to 104 are connected between 2 and 3 to successfully program the SPI FLASH.
Thanks,
Sai Krishna.
你好,
PMOD设置很好。
谢谢,
Sai Krishna。
以上来自于百度翻译
以下为原文
Hi,
Thanks,
Sai Krishna.
