忘了我的最后一篇文章,我只是浏览了一下文档,发现它不仅仅是这个工具包,而且是有用的。
但是,你是否遵循了其中一个例子来验证你的基本设置(ND硬件)是否正常?例如“从桥控制面板1.8文档”中的“RX8X Sunx示例”?这样你就可以验证你的设置,以及你需要采取的步骤(从文档中判断,这看起来不那么简单)。
最后但并非最不重要的,你也可以尝试安装一个COM端口嗅探器看数据通过它,也许这也有助于…
以上来自于百度翻译
以下为原文
Forget my last post, I just read through the documentation and saw that it indeed is useful for more than just this kit.
But still: did you follow one of the examples to verify that your basic setup (nd hardware) is OK? E.g. the "RX8_Sin_X Example for ComPort" from the Bridge Control panel 1.8 documentation? That way you could verify your setup, and the steps you need to take (it doesn't seem so simple judging from the documention).
Last but not least, you can also try to install a COM-Port-Sniffer to look at the data going through it, maybe that helps too...
以上来自于百度翻译
以下为原文
