嗨,我是新的PIC18F66 J94控制器,并试图编译它在MPLABX,但我正在获得编译错误如下:干净的成功(总时间:143MS)使-F NBPix/MaFixFiel-Debug。MK子项目=。建立混淆(2):***没有规则,使目标“构建/默认/生产/源/主。O”,NE由DIST/默认/生产/测试.X.生产。使[ 1 ]:**[构建BILF]错误2]使:[2]:进入目录'E//KNGHH/LUBE控制/输入/测试.X'使-nbPosi/Maun-Fiel-Deult.MK DIST/Deult/Dealth/Test.x.Puth.xHug(2):进入目录'E:/KNGHN/LUBE控制/输入/测试.X'使[2 ]:LeaviNG目录:E//KNGHH/LUBE控制/输入/测试.x'nbPosi/MaFaMeCurrase.MK: 78:目标''.Buffic CONF 'FultEdf[[ 1 ] ]:留下目录'E//KNGHH/LUBE控制/输入/Test.x'NbPosi/MaFix.IMP.MK:39:
time'Buff.Buff-IMPL 'FrueBuffBug失败的配方(退出值2,总时间:18)我在Microchip中引用了一些关于这个问题的链接。WijoTo.com/TLS0101:Lab1,但是问题没有解决。有人能提出一些解决这个问题的方法吗?此外,我还安装了MPLAB XC8编译器V1.38编译器,但在添加新项目时,它不会显示在编译器列表中。我需要一些设置来添加XC8编译器,比如路径环境吗?斯库马
以上来自于百度翻译
以下为原文
Hi,
I am new to PIC18F66J94 Controller and trying to compile it in MPLABX but i am getting compilation error as following.
CLEAN SUCCESSFUL (total time: 143ms)
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[2]: *** No rule to make target 'build/default/production/Source/main.o', needed by 'dist/default/production/test.X.production.hex'. Stop.
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
make[1]: Entering directory 'E:/KNSINGH/Lube Control/Input/test.X'
make -f nbproject/Makefile-default.mk dist/default/production/test.X.production.hex
make[2]: Entering directory 'E:/KNSINGH/Lube Control/Input/test.X'
make[2]: Leaving directory 'E:/KNSINGH/Lube Control/Input/test.X'
nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
make[1]: Leaving directory 'E:/KNSINGH/Lube Control/Input/test.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
BUILD FAILED (exit value 2, total time: 182ms)
I had referred to some link about this problem in microchip.wikidot.com/tls0101:lab1 but the problem is not resolved.
Can anyone please suggest some solution to this problem?
Also i have installed MPLAB XC8 Compiler V1.38 compiler but it is not displayed in the list of compiler when adding new project. Do i need some setting for adding xc8 compiler like path environment?
Regards
Kumar
Attached Image(s)
