Cypress技术论坛
辛太励
8年用户 1206经验值
擅长:20153
执行之后如何知道变量的值
HI论坛
我想知道在执行了一定的执行之后,如何知道变量的值。在调试器中,我在监视窗口中尝试“添加监视”,但是变量的值仍然是0x000,尽管有很多编译运行迭代。
我确信,当我在同一块中切换一个LED时,发生增量,这是我用DSO确认的。
等待答复,
皇家音乐学院
以上来自于百度翻译
     以下为原文
  HI Forum,
    I'd like to know how to know the value of a variable after certain executions have elapsed. I tried "Add Watch" in the watch window under debugger - but the value of the variable remains as 0x0000 inspite of numerous Compile-Run iterations.
    I'm sure that the increment occurs as I also toggle a LED inside the same block which I confirm using a DSO.
    Awaiting replies,
    RAM
辛太励
2019-6-5 12:15:45
鲍勃,
很高兴见到你,兄弟!你在度假?有一些TIM,我得到了你的指导!:)
阿利特,说到点子上,我确实有一个冰块。你能详细说明这个优化项目是如何完成的吗?
问候、公羊
以上来自于百度翻译
     以下为原文
   BOB,
    Good to see you Bro! you were on a holiday ? Been some tym I got guidance from you! :)
    Alryt, coming to the point, I do have an ICE cube. Can you elaborate on how that optimization thing shud be done > ?
    Regards, RAM
