我想你已经从st.com下载了X-CUBE-MEMS1封装。
您可以将其解压缩到例如C:驱动器。
然后执行SW4STM32并将工作空间路径设置为您要尝试的项目,例如:
C: STM32CubeExpansion_MEMS1_V4.0.0 项目多实例 IKS01A2 LSM6DSL_FIFOLowPower SW4STM32 STM32L152RE-核蛋白
然后导入项目:文件 - >导入,选择常规 - >将现有Project插入Workspace,然后单击Next
单击“选择根目录上的浏览”,选择正确的目录,然后单击“确定”,然后单击“完成”。
之后,您在工作区中拥有项目,并且可以构建它。
以上来自于谷歌翻译
以下为原文
I suppose you have downloaded the X-CUBE-MEMS1 package from st.com.
You can extract it, for example to your C: drive.
Then execute the SW4STM32 and set the workspace path to the project you want to try, for example:
C:STM32CubeExpansion_MEMS1_V4.0.0ProjectsMultiExamplesIKS01A2LSM6DSL_FIFOLowPowerSW4STM32STM32L152RE-Nucleo
Then import the project: File -> Import, Select General -> Existing Project into Workspace then click Next
Click Browse on Select root directory, the right directory is selected so you click, OK then Finish.
After that you have the project in your workspace and you can Build it.
您可以将其解压缩到例如C:驱动器。
以上来自于谷歌翻译
以下为原文
