有些人告诉我,我可能会通过一些PGA设置过载ADC?过载是什么意思?
如果PGA增益设置得太高(对于输入范围),则ADC输入的PGA输出将“挂断”为高电平或低电平。
这将使ADC成为一个(缓慢而繁琐的)数字缓冲器。
如果希望PGA和ADC工作在线性(模拟)区域,则需要设置适合PGA输入信号电平的PGA增益值。
这是强制性的“汽车”类比:
如果你的汽车动力转向系统的“放大”过于“大肆宣传”(相当于过度增益),那么每次轻轻推动方向盘都会导致车轮硬左或右转。
将车轮直指前方是非常困难的。
- 鲍勃埃尔金德
签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。
阅读手册或用户指南。
你读过手册了吗?
你能找到手册吗?2。
搜索论坛(并搜索网页)以寻找类似的主题。
不要在多个论坛上发布相同的问题。
不要在别人的主题上发布新主题或问题,开始新的主题!5。
学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。
提供有用的详细信息(请与网页,数据表链接).7。
您的代码中的评论不需要支付额外费用。
我没有支付论坛帖子的费用。
如果我写一篇好文章,那么我一无所获。
以上来自于谷歌翻译
以下为原文
Some people tell me I may overdrive the ADC with some PGA settings?What does the overdrive mean?
If PGA gain is set too high (for the input range), the PGA output to the ADC input will "peg" either high or low. This would render the ADC as little more than a (slow and cumbersome) digital buffer.
If you want the PGA and ADC to be operating in linear (analogue) region, you need to set PGA gain value which is appropriate for the PGA input signal level.
Here's the obligatory "automobile" analogy:
If the "amplification" of your car's power steering system is too "hyped up" (the equivalent of excessive gain), then each gentle nudge of the steering wheel will result in either hard left or hard right turn of the wheels. It would be very difficult to point the wheels straight ahead.
-- Bob Elkind
SIGNATURE:
README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
Summary:
1. Read the manual or user guide. Have you read the manual? Can you find the manual?
2. Search the forums (and search the web) for similar topics.
3. Do not post the same question on multiple forums.
4. Do not post a new topic or question on someone else's thread, start a new thread!
5. Students: Copying code is not the same as learning to design.
6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please).
7. You are not charged extra fees for comments in your code.
8. I am not paid for forum posts. If I write a good post, then I have been good for nothing.
这是强制性的“汽车”类比:
将车轮直指前方是非常困难的。
- 鲍勃埃尔金德
阅读手册或用户指南。
你读过手册了吗?
你能找到手册吗?2。
不要在多个论坛上发布相同的问题。
您的代码中的评论不需要支付额外费用。
我没有支付论坛帖子的费用。
如果我写一篇好文章,那么我一无所获。
以上来自于谷歌翻译
以下为原文
-- Bob Elkind
SIGNATURE:
Summary:
