检查电路板上的INIT_B或PROG_B引脚,它们中的任何一个(或两者)是否接地?
--------不要忘记回复,kudo,并接受为解决方案.----------------------------
以上来自于谷歌翻译
以下为原文
Check the INIT_B or PROG_B pin on your board, is any of them (or both) grounded?------------------------------------------------------------------------------------------------------------
Don't forget to reply, kudo, and accept as solution.
以上来自于谷歌翻译
以下为原文
