Microchip
马丹丹
8年用户 186经验值
LoRa技术评估套件无法解密Payload
我正在使用LoRa技术评估套件来实施LoRa技术。我已经按照“LoRa技术评估套件用户指南”建立了一切。但是从服务器上查看数据库,我不能读取RN2903节点正在发送的数据中的含义。附件是截图。有人知道接下来要做什么吗?
以上来自于百度翻译
      以下为原文
    Am using LoRa Technology Evaluation Suite to implement LoRa Tech. i have set up everything according to "LoRa Technology Evaluation Suite user's Guide". But looking at the database from the server, i cant reading meaning into data the RN2903 node is sending. Attached is the screenshot. Does anyone know what next to do?
   Attachment(s)
Lora DevUtility Snapshot - Copy.doc (172.00 KB) - downloaded 104 times
回帖(2)
张喆
2019-5-23 07:06:05
尘埃有效载荷中的信息是光传感器和温度传感器测量。详情见“LoRa∈Mote用户指南”。
以上来自于百度翻译
      以下为原文
    The information in mote payload is light sensor and temperature sensor measurements.
See "LoRa® Mote User’s Guide" for details.
凌流浪
2019-5-23 07:19:37
非常感谢威廉姆斯的回复。您有没有办法查看发送数据包的接收信号强度和/或开发工具包中的数据包丢失?关于希戈
以上来自于百度翻译
      以下为原文
    Many thanks Williams for your response,
Do you have any means of viewing the Received signal strength (RSS) of the transmitted Packets and/or the packet losses from this development kit?
Regards
Chigo
