Microchip
杨会
7年用户 228经验值
WiFi G演示板编译但无法运行
我在演示板上运行WiFi G演示和声固件有问题。它编译好,但在初始化时停止调试模式。我在3.25V的ICD3上为演示板供电。问题似乎是:TCPIpHyMultMeal.C中的.TCPIPSTACKISRUNSTATE():WHEMACSTATT和LT;0和CaltScPIPpStaskBurnNETWORD(),这应该是方兴未艾的,对吧?其他人看到了解决的办法吗?我使用的是:-和谐框架:V1.10,和声配置器:V1.0.10,MPLABX IDE:V3.51,调试器:ICD 3与ICSP适配器,Java:1.80Y91;64位,系统:Mac OS X105.5运行在X8664上
以上来自于百度翻译
      以下为原文
    I have problems running the WiFi G Demo HARMony firmware on a Demo board.
It compiles fine but stops in Debug mode during initialisation. I am powering the demo board from the ICD3 at 3.25v.
Problem seems to be in:
_TCPIPStackIsRunState() in tcpip_manager.c, where macStat < 0 and calls TCPIP_STACK_BringNetDown().
This should run out-of-the-box, right? Anyone else seen a solution to this?
I am using:-
Harmony Framework: v1.10, Harmony Configurator: v1.0.10.0, MPLAB X IDE: v3.51, Debugger: ICD 3 with ICSP adapter, Java: 1.8.0_91; 64-Bit, System: Mac OS X 10.9.5 running on x86_64
回帖(4)
张润
2019-5-9 08:48:17
谢谢。我已经成功地建立和运行了V310C固件更新,但没有LED开启。我正在用XC32 V1.33编译(V1.42没有编译)。有什么想法吗?
以上来自于百度翻译
      以下为原文
    Thanks. I have built and run the v310C firmware update successfully but no LEDs turn on. I am compiling with XC32 v1.33 (v1.42 does not compile).
Any ideas?
张润
2019-5-9 08:59:45
更正:似乎我需要为外部板供电(DOH)。我已经设立了板是由现在安装的ICD3.FW更新供电。谢谢你的帮助!
以上来自于百度翻译
      以下为原文
    Correction: seems I need to power the board externally (doh). I had the board set up to be powered by the ICD3.
FW update now installed.. Thanks for your help.!
陈晨
2019-5-9 09:06:57
XC32 V1.42是协调的正确编译器V1.10i能够在V1.08或V1.09中获得与Hyg论坛中的编译器错误相关的挖掘工作。我假设您在MHC上有正确的版本。您只做了一个构建和程序,没有改变什么?
以上来自于百度翻译
      以下为原文
    XC32 V1.42 is the correct compiler for Harmony V1.10
I was able to get mine work in V1.08 or V1.09
Deal with the Compiler errors in the Harmony Forum.
I assume you have the correct Version on MHC.
And that you only did a Build and program and did not change anything?
张润
2019-5-9 09:15:20
是的,只有建造和程序,没有变化会在更进一步的和谐中再次出现。
以上来自于百度翻译
      以下为原文
    yes, build and program only, no changes
will chase up further in Harmony forum
Thanks again.!
