ST意法半导体
萧持毅
8年用户 321经验值
擅长:控制/MCU
无法在电机控制工作台中设置端口和引脚以禁用过电流保护
我无法更改电机控制工作台中过电流保护禁用的端口和引脚。所有启用都是正确设置的。我可以编辑输出文件并更改引脚但不能在MCWB应用程序中。这是一个错误还是我错过了什么?
照片显示选项灰色。
其次,当我启用ICL Shutout选项时,我收到一条警告:''默认STM32 PMSM FOC FW库不支持此功能''
如何启用此功能?
埃里克
#mcwb-FOC端口引脚选择
以上来自于谷歌翻译
以下为原文
I am unable to change the port and pin for the Over current Protection Disable in Motor control workbench.  All the enables for this are set properly.  I can edit the output files and change the pin but not in the MCWB application.  Is this a bug or am I missing something?
Photo included shows option greyed out.
Secondly When I enable the ICL Shutout option I get a warning saying : ''feature not supported by default STM32 PMSM FOC FW library''
How do I enable this feature?
Eric
#mcwb-foc-port-pin-selection
张秀兰
2019-4-16 14:02:08
Ciao Ericc
 我读到你已经解决了这个问题,但是,很明显,我想为所有其他人更好地解释它。
 过电流保护禁用功能旨在与过电压动作“打开低侧开关”一起使用。因此要启用需要以下三个步骤
 1)在功率级启用过流保护禁用网络
 2)选择“打开低侧开关”作为驱动器管理中的过电压动作,并通过HW启用过电压禁用过电流保护复选框
 3)设置过流保护禁用端口和引脚
 关于您的帖子的第二点,即使可以在工作台中启用ICL“涌入电流限制”,该代码也不会在3.0版的固件中实现。这意味着无法使用此功能。该功能一直保留在WB中,以供将来开发。
 最好的祝福
 梁咏琪
以上来自于谷歌翻译
以下为原文
Ciao Ericc
I read that you have already resolved the issue but, to be clear, I want to explain better it for all other people.
The over current protection disabling feature is intended to be used together with the on over voltage action ''Turn on low side switches''. So to enable are required the three steps below
1) Enable the Over-current protection disabling network in the power stage
2) Select ''turn on low side switches'' as on over voltage action in the drive management and enable on over-voltage disable over-current protection by HW check box
3) Set the over current protection disabling port and pin
Regarding the second point of your post, even if it is possible to enable the ICL ''Inrush current limitation'' in the workbench, the  the code is not implemented in the firmware the version 3.0. This means that this feature can't be used. The feature has been kept in the WB for future developments.
Best regards
Gigi
