嗨,
如果是Zynq linux驱动程序,你正在寻找参考
http://www.wiki.xilinx.com/Linux+Drivers
http://www.wiki.xilinx.com/Zynq+Linux+USB+Device+Driver
问候
普利文
--------------------------------------------请注意 - 请注明
如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K--
-----------------------不要忘记回答,kudo,并接受为解决方案.-------------
以上来自于谷歌翻译
以下为原文
Hi,
If it is Zynq linux driver you are looking for refer to
Regards
Praveen
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
Don’t forget to reply, kudo, and accept as solution.
嗨,
问候
普利文
以上来自于谷歌翻译
以下为原文
Hi,
Regards
Praveen
