批量代码是正确的早期250MHz硅(A1),管理它的方式进入样本库存。如前所述,今天所有的股票都已经转入A3。Bigjon,如果你想给我发一个你的联系细节的PM,我可以得到一些替换的A3部分。(或者,如果你有一个MDC帐户,所有可用的材料现在旋转到A3,这样你就可以订购新的样品…)
以上来自于百度翻译
以下为原文
The lot code is correct for early 250Mhz silicon (A1) that managed it's way into sample inventory. As mentioned, everything has transitioned over to A3 in stock today though.
BigJon if you want to send me a PM with your contact details, I can get some replacement A3 parts sampled out. (Or, if you've got an mDirect account, ALL available material is now rotated to A3 so you can order new samples...)
以上来自于百度翻译
以下为原文
