Cypress技术论坛
王建华
8年用户 350经验值
NAND-FLASH S34ML08G1编写和读取不成功
你好
这是第一次在8位配置与s34ml08g1 nand-flash记忆工作。
读数据存储器时总的数据是一样的:b0001000(0x10)。
WP为高,R/B为Vcc(3.3V)。
Pins Vcc(12-37)是3.3V,引脚13-48-25是GND。
为了考试,写一个读了不同的行和列(块,页面和栏目)
这件事有什么暗示吗?
谢谢
哈维尔
以上来自于百度翻译
     以下为原文
  Hello
    It is the first time working with S34ML08G1 NAND-FLASH memory in 8 bit configuration.
    When reading the data memory always the data is the same: b0001000 (0x10).
    WP is high, R/B# is pull-up to Vcc (3.3V).
    Pins Vcc (12-37) are 3.3V and pins 13-48-25 are gnd.
    For the test, writes an reads are made to different rows and columns (blocks, pages and columns)
    Is any hint about this case?
    Thanks
    Javier
回帖(2)
h1654155275.5809
2019-2-22 14:52:22
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
陈玉兰
2019-2-22 15:01:23
你好,
只是想知道什么版本的NAND LLD你用的是和你在哪里下载呢?我注意到飞索文件下载部分似乎感动;和唯一的LLD的是2013,我可以找到在软件里很古老。
问候,John W.
以上来自于百度翻译
     以下为原文
  Hello,
    Just wondering - what version of the NAND LLD are you using - and where did you download it from?  I noticed the Spansion file download section seems to have moved; and the only LLD's are from 2013 that I can find - quite ancient in software years.
    Regards,
John W.
