ADI 技术
凌云志
8年用户 220经验值
请问AD9954的IO_UPDATE怎么控制?
AD9954的IO_UPDATE的是怎么控制的,现在只能把地址写到寄存器中,不能输出到SDIO,
回帖(5)
凌云志
2019-2-21 10:44:38
现在状态机都能有输出,只是给IO_UPDATE信号好像时序不对,不能把buffer里的数据传到寄存器(register),
代码如下
李淑嘉
2019-2-21 10:55:31
需要注意:1# The I/O UPDATE signal is edge detected to generate a single rising edge clock signal that drives the register bank flops. The I/O UPDATE signal has no constraints on duty cycle. The minimum low time on I/O UPDATE is one SYNC_CLK clock cycle. 2# The I/O UPDATE pin is set up and held around the rising edge of SYNC_CLK and has zero hold time and 4 ns setup time. 请问你的IO Update信号是如何给出的?
凌云志
2019-2-21 11:02:37
引用: VERTEX2016 发表于 2019-2-21 10:55
需要注意:1# The I/O UPDATE signal is edge detected to generate a single rising edge clock signal that drives the register bank flops. The I/O UPDATE signal has no constraints on duty cycle. The minimum low time on I/O UPDATE is one SYNC_CLK clock cycle. 2# The I/O UPDATE pin is set up and held arou ...
谢谢你的回复,我的IO_UPDATE是设置FPGA的输出端口,为寄存器类型,用FPGA系统时钟20MHz上升沿来变化的,在写完数据后就把IO_UPDATE拉高一个时钟周期,再下一个时钟上升沿拉低。但是我用SignalTap捕捉信号,显示FPGA连接到AD9954的时钟SCLK一直为低电平,没有变化。IO_UPDATE也没有变化。我现在感觉是AD9954的时钟有问题。
凌云志
2019-2-21 11:16:58
谢谢,我现在问题解决了,可以产生正弦波,还想再问一下,用RAM的直接转换模式怎样设置PSK调制呢
