我用cycontrol程序程序I2C串行EEPROM在我开发的系统有问题。它似乎正常(检查I2C的SCL和SDA与示波器)但它总会导致失败。有人有任何想法来帮助解决这个问题吗?这种方法适合编程的SPI Flash,也对我的评估板但我最终设计需要从I2C串行EEPROM下载。
系统:
Xilinx VIETEX 7 VC707评估板
inrevium tb-fmcl-u***30夹层板柏CYUSB3014芯片的特点与1mbit USB3 I2C串行EEPROM
以上来自于百度翻译
以下为原文
I am having issues using the CyControl program to progam the I2C Serial EEPROM on my development system. It appears to func
tion properly (checked I2C scl and sda with oscilloscope) but it always results in a failure. Does anyone have any ideas to help solve this issue. This approach works fine with programming an SPI Flash that is also on my evaluation board but in my final design it needs to download from the I2C Serial EEPROM.
System:
Xilinx Virtex 7 VC707 Evaluation Board
Inrevium TB-FMCL-USB30 Mezzanine Board with Cypress CYUSB3014 USB3 with 1Mbit I2C Serial EEPROM
