是德科技
孙燕冉
7年用户 328经验值
PNA-X显示适配器多显示器问题
您好,我遇到一个奇怪的显示适配器问题,只发生在1个PNA-X系统而不是另一个2.正如您在附件中看到的,如果您查看设备管理器,通常会看到2
列出的显示适配器,这是我们的2个PNA-X系统的情况。
但是,在我们的PNA-X#3上,它只显示1个显示适配器。
我们将外部LCD显示器连接到PNA-X背面的vga连接器。
我的问题是如何让有问题的PNA-X系统显示2个显示适配器,因为它表现出一些我认为与此相关的奇怪的图形故障。
谢谢,rokEdited by:rok on 2014年4月21日下午12:35 04_17_2014-pnax3(仅1个显示适配器).PNG44.2 KB04_17_2014-pnax3(仅1个显示适配器).PNG44.2 KB04_17_2014-pnax2(显示2个显示适配器)
.PNG47.6 KB
以上来自于谷歌翻译
     以下为原文
  Hello,
I am encountering a strange display adapter issue that is only occurring on 1 of the PNA-X systems and not on the other 2. As you can see in the attachments, if you look under the device manager, you normally would see 2 display adapters listed, which is the case for 2 of our PNA-X systems. However, on our PNA-X #3, it is only showing 1 display adapter. We are attaching an external LCD display to the vga connector in the back of the PNA-X. My question is how to get the PNA-X system in question to show 2 display adapters, since it is exhibiting some strange graphical glitches that I believe is related to this.
Thanks,
rok
Edited by: rok on Apr 21, 2014 12:35 PM
附件
回帖(3)
王静
2019-2-19 15:31:32
您是否尝试右键单击桌面以进行显示设置,转到高级设置,选择英特尔图形选项卡,然后选择克隆显示?
如果将dpi设置为120以外的任何值,我也会遇到显示问题。希望这会有所帮助
以上来自于谷歌翻译
     以下为原文
  did you try right clicking on desktop for display settings, go to advanced settings, choose intel graphics tab, then choose clone display?
I have also run into display issues if dpi is set to anything other than 120.
Hope this helps
孙燕冉
2019-2-19 15:42:49
嗨,谢谢你的建议。
字体大小已设置为“120DPI”,我尝试了克隆显示,但仍然有相同的图形问题,设备管理器中只显示1个显示适配器。
其中一些图形问题包括PNA-X显示分辨率在重启后自动更改为较低分辨率,无论之前的设置如何。
如果其他人有其他建议尝试,那将是很好的。
谢谢,rok
以上来自于谷歌翻译
     以下为原文
  Hi,
Thanks for the advice. The font size is set to '120DPI' already and I tried the clone display, but still have the same graphics issues, with only 1 display adapter showing up in the Device Manager. Some of these graphic issues include the PNA-X display resolution being automatically changed to a lower resolution after reboot, regardless of what was the setting before. If someone else has some other advice to try, that would be great.
Thanks,
rok
孙燕冉
2019-2-19 16:01:42
引用: 蓝色冰汐 发表于 2019-2-19 19:35
嗨,谢谢你的建议。
嗨,我终于想出了如何在双显示器设置中重新启动时停止基于Windows XP的PNA-X将显示分辨率更改为默认的低分辨率800x600:运行'msconfig'转到'启动'选项卡。
查找“igfxpers.exe”条目。
取消选中以防止它运行。
可能有2个条目。
希望它可以帮助那里的人,rok
以上来自于谷歌翻译
     以下为原文
  Hi,
I finally figured out how to stop the Windows XP-based PNA-X from changing the display resolution to the default low-resolution 800x600 when restarting in a dual monitor setup:
Run 'msconfig'
Go to the 'Startup' tab.
Look for 'igfxpers.exe' entries. Uncheck that to prevent it from running. There might be 2 entries.
Hope it helps someone out there,
rok
