STM32/STM8技术论坛
曾玲娟
8年用户 192经验值
请问F373系列如何使用HAL库配置SDADC?
以前没有过F373系列,现在项目需要,有高手给知道一下怎么使用HAL库配置SDADC
回帖(8)
何秀珍
2019-2-18 08:08:38
在STM32CubeMX中很容易配置SDADC的。
李富贵
2019-2-18 08:26:05
没有用过,只能帮楼主加人气了。
林芳
2019-2-18 08:37:46
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
刘宇
2019-2-18 08:53:58
网上有教程的
易里更
2019-2-18 09:03:36
STM32F373的SDADC编写过多通道数据采集
ADC_InitStructure.ADC_ScanConvMode = ENABLE;//扫描方式,这个一定要打开
ADC_RegularChannelConfig(ADC1, ADC_Channel_0 , 1, ADC_SampleTime_239Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5);
设置好采集顺序,dma会先发送先采集的通道的数据,后发送后采集的通道的数据
肖青
2019-2-18 09:15:09
太新。。。没用过。。。
happybaby8882
2019-5-24 16:43:20
/* SDADC1 init function */
void MX_SDADC1_Init(void)
  SDADC_ConfParamTypeDef ConfParamStruct = {0};
  /** Configure the SDADC low power mode, fast conversion mode,
  slow clock mode and SDADC1 reference voltage
  hsdadc1.Instance = SDADC1;
  hsdadc1.Init.IdleLowPowerMode = SDADC_LOWPOWER_NONE;
  hsdadc1.Init.FastConversionMode = SDADC_FAST_CONV_ENABLE;
  hsdadc1.Init.SlowClockMode = SDADC_SLOW_CLOCK_DISABLE;
  hsdadc1.Init.ReferenceVoltage = SDADC_VREF_EXT;
  if (HAL_SDADC_Init(&hsdadc1) != HAL_OK)
    Error_Handler();
  /** Set parameters for SDADC configuration 0 Register
  ConfParamStruct.InputMode = SDADC_INPUT_MODE_SE_OFFSET;
  ConfParamStruct.Gain = SDADC_GAIN_1;
  ConfParamStruct.CommonMode = SDADC_COMMON_MODE_VSSA;
  ConfParamStruct.Offset = 0;
  if (HAL_SDADC_PrepareChannelConfig(&hsdadc1, SDADC_CONF_INDEX_0, &ConfParamStruct) != HAL_OK)
    Error_Handler();
  /** Configure the Regular Channel
  if (HAL_SDADC_AssociateChannelConfig(&hsdadc1,
                SDADC_CHANNEL_4 + SDADC_CHANNEL_5 + SDADC_CHANNEL_6,
                SDADC_CONF_INDEX_0) != HAL_OK)
    Error_Handler();
  /** Calibrate the SDADC in configuration 0
        HAL_SDADC_CalibrationStart(&hsdadc1, SDADC_CALIBRATION_SEQ_1);
        if (HAL_SDADC_PollForCalibEvent(&hsdadc1, 50) != HAL_OK){
    Error_Handler();
  /** Configure The Regular Mode
  if (HAL_SDADC_SelectRegularTrigger(&hsdadc1, SDADC_SOFTWARE_TRIGGER) != HAL_OK)
    Error_Handler();
  if (HAL_SDADC_ConfigChannel(&hsdadc1, SDADC_CHANNEL_4, SDADC_CONTINUOUS_CONV_ON) != HAL_OK)
    Error_Handler();
void HAL_SDADC_MspInit(SDADC_HandleTypeDef* sdadcHandle)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  if(sdadcHandle->Instance==SDADC1)
  /* USER CODE BEGIN SDADC1_MspInit 0 */
  /* USER CODE END SDADC1_MspInit 0 */
    /* SDADC1 clock enable */
    __HAL_RCC_SDADC1_CLK_ENABLE();
    __HAL_RCC_GPIOB_CLK_ENABLE();
    /**SDADC1 GPIO Configuration
    PB0     ------> SDADC1_AIN6P
    PB1     ------> SDADC1_AIN5P
    PB2     ------> SDADC1_AIN4P
    GPIO_InitStruct.Pin = Temperature_Pin|BGVoltage_Pin|BGCurrent_Pin;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    /* SDADC1 DMA Init */
    /* SDADC1 Init */
    hdma_sdadc1.Instance = DMA2_Channel3;
    hdma_sdadc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_sdadc1.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_sdadc1.Init.MemInc = DMA_MINC_ENABLE;
    hdma_sdadc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
    hdma_sdadc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
    hdma_sdadc1.Init.Mode = DMA_NORMAL;
    hdma_sdadc1.Init.Priority = DMA_PRIORITY_HIGH;
    if (HAL_DMA_Init(&hdma_sdadc1) != HAL_OK)
      Error_Handler();
    __HAL_LINKDMA(sdadcHandle,hdma,hdma_sdadc1);
  /* USER CODE BEGIN SDADC1_MspInit 1 */
  /* USER CODE END SDADC1_MspInit 1 */
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI|RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.LSIState = RCC_LSI_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_ADC1
                              |RCC_PERIPHCLK_SDADC;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
  PeriphClkInit.SdadcClockSelection = RCC_SDADCSYSCLK_DIV12;
  PeriphClkInit.Adc1ClockSelection = RCC_ADC1PCLK2_DIV2;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    Error_Handler();
  HAL_PWREx_EnableSDADC(PWR_SDADC_ANALOG1);
  /** Enables the Clock Security System
  HAL_RCC_EnableCSS();
郝欣
2021-12-6 14:28:54
楼主现在会配置了嘛
