ST意法半导体
李明聪
8年用户 1218经验值
LIS2DS12是否需要I2C上拉?
我正在使用STEVAL-MKI174V1适配器板进行LIS2DS12评估。我检查了STEVAL-MKI174V1的原理图,我有两个问题:
STEVAL-MKI174V1的Vdd可以是3.3V而不会损坏LIS2DS12,因为它只能处理2.2V(由于调节器,似乎答案是肯定的)我是否需要在适配器板上添加外部上拉到SDA,SCL线路?
谢谢,
基兰
以上来自于谷歌翻译
以下为原文
I am using STEVAL-MKI174V1 adapter board for LIS2DS12 evaluation. I checked the schematic of STEVAL-MKI174V1 and I have two questions:
  • Can Vdd for STEVAL-MKI174V1 be 3.3V without damaging LIS2DS12 because it can handle only 2.2V (It seems answer to this will be yes because of regulator)
  • Do I need to add external pull-ups to SDA, SCL line even after adapter board ?
Thanks,
Kiran
曾玲娟
2019-2-15 16:39:13
如果适配器上没有调节器和电平转换器,则无法将其连接到3.3V。默认情况下不会填充,您可以在电路板的底部检查它。是的,您需要在SDA和SCL引脚上进行上拉。
以上来自于谷歌翻译
以下为原文
  • If the regulator and level shifter is not populated on the adapter you cannot connect it to 3.3V. By default is is not populated, you can check it on the bottom side of the board.
  • Yes, you need pull-up on SDA and SCL pins.
