Microchip
黎菁菁
8年用户 574经验值
ICD4与REAL ICE那个好
嗨,所以…我还没有看到ICD4和真实冰的比较。ICD4对PIC微控制器编程特别快,特别是DSPIC?如果你已经有了真正的冰,购买ICD4的好处是什么?谢谢你,多米尼克
以上来自于百度翻译
      以下为原文
    Hi,
So.. i haven't seen any comparison between icd4 and real-ice. Is icd4 faster for programing PIC microcontrollers, especially dsPIC? what are the benefits buying icd4 if you already have real-ice?
Thank you
Dominik
回帖(15)
傅双育
2019-1-25 11:30:40
ICD4比真正的冰快,对于一些较大的存储部件来说,它的速度是它的两倍。把它看作是类固醇上的ICD3,并且会有更多的调试特性,而ICD3没有。
以上来自于百度翻译
      以下为原文
    ICD4 is faster than REAL ICE, for some larger memory parts its twice as fast.  Think of it as an ICD3 on steroids and there will be more debug features added that ICD3 does not have.
陈晨
2019-1-25 11:45:03
更快,更少的钱比真正的冰?????
以上来自于百度翻译
      以下为原文
    Faster and Less Money than the Real ICE????
李天竹
2019-1-25 11:58:55
基于人们在Web上发布的内容(例如SEGGER比较),Read ICE的速度与ICD3相同。如果ICD4比ICD3快,那么它比实际的还要快。ICD4内部有较新的SPARAN-6 FPGA和PIC32。一定很快。另一方面,ICD3也有FPGA和DSPIC33,但在DSPIC33 EP芯片上的编程速度比基于PIC16F1454的单芯片设计慢3倍。如果ICD4比ICD3快2倍,那么仍有一些方法可以满足NSDSP的速度。
以上来自于百度翻译
      以下为原文
Based on what people post on the Web (e.g. Segger comparisons), ReadICE is the same speed as ICD3. If ICD4 is faster than ICD3 then it is also faster than RealICE.
ICD4 has newer Sparan-6 FPGA and PIC32 inside. Must be very fast. On the other hand, ICD3 also had FPGA and dsPIC33, yet it was 3 times slower in programming dsPIC33EP chips than my single-chip design based on PIC16F1454. If ICD4 is only 2 times faster than ICD3, there's still some way to go to match NSDSP speed.
李维兴
2019-1-25 12:06:49
LOL:不管怎样,ICD4比每单位249.95美元的Realice要少得多:HTTP://www. McCHIIPDUNCT.COM/OptudiSalk.ASPX?关键词:DV164045
以上来自于百度翻译
      以下为原文
LoL:
Anyway, ICD4 is less money than RealICE at US$249.95 per unit: http://www.microchipdirect.com/ProductSearch.aspx?Keywords=DV164045
