你好,我们目前正在为WM8904音频编解码器增加一个驱动程序。这主要是因为需要一个更精确的FLL,这个特定的设备允许。它将与发布周期中的新设备配对,但我们也将使配置与一些现有的家庭一起工作。如果您正在编写自己的编解码器驱动程序,那么我同意使用I2C的示例已经可用。我们经常这样做,例如,您可以使用AK464 2驱动程序作为参考。
以上来自于百度翻译
以下为原文
Hello,
We are currently in the process of adding a driver for the WM8904 audio codec. This is primarily driven by the need for a more precise FLL that this specific device allows. It will be paired with a new device that is in the release cycle, but we will also make configurations work with some existing families.
If you are writing your own codec driver, I agree an example that uses I2C is already available. We do this regularly and for example you can use the AK4642 driver for a reference.
以上来自于百度翻译
以下为原文
Hello,
