An important piece of PSoC Creator has a problem and may not work correctly. Please restart PSoC Creator.This error shows up when the following are being initialized:
CyDesigner.Common.Db.DeviceDb.Catalog.CyDcPluginAdditionally, when closing PSoC Creator, I get this error (and others which are similar):
CyDesigner.Common.ProjMgmt.CyPrjMgr
CyDesigner.Common.Db.CyS3Db.CyS3DbFactory
CyDesigner.Device.FitterPSoC.CyFitterPSoCPlugin
CyDesigner.Device.FitterFM.CyFitterFmPlugin
This product had trouble launching on your computer. Technical error reason: An exception was thrown when trying to fully close plugin 'FM Fitter:a7614a5f-f176-4ec2-b000-98356a8f3dc8'. Exception Message: Object reference not set to an instance of an object..I've tried to do a fresh reinstall several times, as well as uninstalling other PSoC packages. I had a version of PSoC Creator in the 3.X series working earlier in the week without these issues, so I'm not sure how to fix this. Does anyone have any suggestions?
引用: muuwfwr 发表于 2019-1-4 10:52
苹果和Linux操作系统支持PSoC®软件和工具包KBA875
以上来自于百度翻译
Mac OS X El Capitan on Parallels Desktop 11 running Windows 10I can't do much about my macOS version, but I thought it might be worth trying to downgrade Parallels. At first glance it looks like it's working in Sierra with Parallels 11 and Windows 10. But I guess if I do run into issues, I'm out of luck...
