STM32/STM8技术论坛
符敛招
7年用户 165经验值
STM32L011F4P6的MSI在配置成65.536K的频率后无法仿真
MSI在配置成65.536K的频率后直接无法仿真,程序跑飞。
(MSI_RANGER_0或1)都不行,RANGER_2或以上就可以。
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  RCC_OscInitStruct.MSICalibrationValue = 0;
  RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_0;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  }//这配置不行
  RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_2;
  }//这就可以
回帖(6)
杨文英
2018-12-29 09:50:43
是真跑飞了,还是 SWD 断了?写一个闪灯程序,把 SWD 速度降下去(~5kHz)试试看。
符敛招
2018-12-29 09:57:34
LED FLASH程序加了,没有反应,我后面调试直接用例程里面的PWR_LPR,
其中这一段
void SystemClock_Decrease(void)
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  /* Enable Power Control clock */
  __HAL_RCC_PWR_CLK_ENABLE();
  /* The voltage scaling allows optimizing the power consumption when the device is
     clocked below the maximum system frequency, to update the voltage scaling value
     regarding system frequency refer to product datasheet.
     Low power sleep mode can only be entered when VCORE is in range 2. */
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
  /* Enable MSI Oscillator */
  RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_5;
  RCC_OscInitStruct.MSICalibrationValue = 0x00;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct)!= HAL_OK)
    /* Initialization Error */
    while(1);
  /* Select MSI as system clock source and configure the HCLK, PCLK1 and PCLK2
     clocks dividers */
  RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0)!= HAL_OK)
    while(1);
  /* Set MSI range to 0 */
  __HAL_RCC_MSI_RANGE_CONFIG(RCC_MSIRANGE_5);
  __HAL_RCC_MSI_RANGE_CONFIG(RCC_MSIRANGE_4);
  __HAL_RCC_MSI_RANGE_CONFIG(RCC_MSIRANGE_3);
  __HAL_RCC_MSI_RANGE_CONFIG(RCC_MSIRANGE_2);
  __HAL_RCC_MSI_RANGE_CONFIG(RCC_MSIRANGE_1);
  __HAL_RCC_MSI_RANGE_CONFIG(RCC_MSIRANGE_0);
在RANG1的时候就直接没有反应了,仿真器也退出了,
还有一个奇怪的现象就是
我用开发板STM32L011K4这个型号运行这个例程是没有问题的。
但是把这个程序放到STM32L011F4这个型号上面就不行了,硬件上也没什么差别。
杨文英
2018-12-29 10:10:41
其中这一段
先试试看不接仿真能不能闪灯。如果不可以那就要去挖掘 HAL 的源代码了。如果不接仿真可以闪灯那就是仿真断了,你需要把 SWD 速度进一步降下去。
王聪
2018-12-29 10:15:44
我也遇到了这个问题,请问下楼主怎么解决的
陈斌
2018-12-29 10:26:28
将SWD的max clock改一下,试过没?
lee_st
2018-12-29 15:16:16
很简单的东西啊
