是德科技
秦涌安
8年用户 193经验值
怎么使用Command Expert将SMU设置为加载?
大家好,与prev post有关,我如何设置通过Command Expert SMU(B2902A)作为有源恒流负载放电,同时记录数据?
史蒂夫
以上来自于谷歌翻译
     以下为原文
  Hi all,
related to prev post, how do i set up through Command Expert the SMU (B2902A) to act as active constant current load for discharging a battery, whilst logging data?
Steve
秦涌安
2018-12-21 16:40:12
没问题,根据其他文章,它不能很好地工作,所以在Labview中用VI来捕获数据,我认为在为SMU捕获数据的同时记录到USB对B2902A要求太高了吗?
史蒂夫
以上来自于谷歌翻译
     以下为原文
  its ok, it doesnt work very well according to other posts, so did a VI in Labview to capture the data, I assume that logging to USB whilst capturing data for the SMU is just too demanding for the B2902A then?
Steve
