你好奥利弗,
是的,您的经验是正确的,磁力计数据是右对齐的,加速度计数据是合理的,在正常模式下,数据是12位表示,这意味着LSB中最低的4位始终为0。在低功耗模式下,数据以8位表示,这意味着只有MSB具有实数,LSB始终为00h。
我希望这能澄清您的问题,并随时发布您想要讨论的任何其他主题。
谢谢,
蒂亚戈雷斯
以上来自于谷歌翻译
以下为原文
Hello Oliver,
Yes, your experience is correct, the magnetometer data is right-justified and the accelerometer data is left�justified, in normal mode, the data is in 12�bit representation which means the lowest 4 bit in LSB are always 0s. In low power mode, the data is in 8�bit representation which means only MSB has real dataand LSB is always 00h.
I hope this clarifies your question, and please feel free to post any other topics that you would like to discuss.
Thank you,
Thiago Reis
你好奥利弗,
谢谢,
蒂亚戈雷斯
以上来自于谷歌翻译
以下为原文
Hello Oliver,
Thank you,
Thiago Reis
