是德科技
张秀荣
8年用户 236经验值
HP 8562A频谱分析仪连接错误GPIB 82357B
我有一台旧的频谱分析仪HP 8562A型号和GPIB Agilent 82357B。
我想通过Agilent Connection Expert连接它。
在GPIB 82357B就绪指示灯亮起。
USB-GPIB接口无法被连接专家识别。
我收到了这个错误:'通讯失败'。
此外,我还没有尝试通过Interactive IO检查“自动识别此仪器”。
我没有连接它。
我该如何配置呢?
ACE_1.png113.8KBfotoğraf.JPG1.9MB
以上来自于谷歌翻译
     以下为原文
  I have a old spectrum analyzer HP 8562A model and GPIB Agilent 82357B. I want to connecting it by Agilent Connection Expert. on GPIB 82357B Ready Light is ON.
USB-GPIB interface it isn't recognized by the connection expert. i received this error: 'there was a communication failure'. Also i tried not check 'auto-identify this instruments' by Interactive IO. i didn't connection it. How I can configure it?
附件
李健
2018-12-6 16:07:53
在您的图像ACE_0.png中,您应该选择*更改属性*并取消选中“*自动识别此仪器*”,因为连接专家将仅使用** IDN?*查询来识别本仪器无法理解的仪器。
一旦你这样做,你应该看到红色的X消失,你应该看到绿色的支票。
然后,您可以在窗口顶部附近的图标功能区中选择* Interactive IO *以与之通信。
在您的图像ACE_1.png中,您有两个问题:1)您输入了“* GPIB0 :: 10:INSTR *”而不是“* GPIB :: 10 :: INSTR *”。
2)您不能使用** IDN?*与本仪器通信,您需要使用* ID?*查询来识别它。
麦克风
以上来自于谷歌翻译
     以下为原文
  In your image ACE_0.png you should select *Change Properties* and uncheck "*Auto-identify this instrument*" as the connection expert will only use the **IDN?* query to identify instruments, which this instrument does not understand. Once you do so you should see the red X go away and you should see a green check instead. THEN you can select the *Interactive IO* in the icon ribbon near the top of the window to talk to it.
In your image ACE_1.png you have two problems: 1) You have entered "*GPIB0::10:INSTR*" instead of "*GPIB::10::INSTR*". 2) You cannot use **IDN?* to communicate with this instrument, you need to use the *ID?* query to identify it.
Mike
