嗨,
您可以尝试在HTS221_Set_PowerDownMode指令后读取CTRL_REG1(0x20h)吗?
什么是读取值?
请记住,驱动程序中的HTS221_ReadReg和HTS221_WriteReg指令必须使用SPI重新映射,而HTS221 SPI则需要3线。
您是否检查过设备是否正确读取和写入SPI级别?
问候
安东内拉
以上来自于谷歌翻译
以下为原文
Hi,
Can you try to read the CTRL_REG1 (0x20h) after the HTS221_Set_PowerDownMode instruction?
What is the read value?
Keep in mind that HTS221_ReadReg and HTS221_WriteReg instructions in the driver, have to be remapped with functions using SPI and that for HTS221 SPI is 3 wires.
Do you have check that the device is correctly read and written at level of SPI?
Regards
Antonella
嗨,
什么是读取值?
问候
安东内拉
以上来自于谷歌翻译
以下为原文
Hi,
Regards
Antonella
