nuc是全新的,使用hdmi 2.0电缆4k(60Hz)连接到接收器。
我也尝试了4种不同的4k电缆(接收器有3个hdcp 2.2端口,它连接到端口1)
从接收器连接到投影仪与hdmi 2.0电缆4k(60Hz)我也尝试了不同的4k电缆 - 短,长。
投影机只有一个输入hdcp 2.2所以我连接到这个端口。
当将海峡连接到高清电视(不是4k)时,nuc工作正常,但是当接收器涉及它的闪烁时不会。
将它连接到投影仪时,闪烁较少,但仍有一些可能会掉线 - 然后我必须重新启动。
在Chrome浏览器中它可以发生,但比Netflix应用程序或Microsoftedge少得多。
YouTube和其他网站总是运作完美(高清,4k,hdr ......)
我还测试了朋友的第6代nuc,它运行正常。
我还有一台10年历史的电脑,它与投影机和接收器完美配合(win7连接方式与hdmi相同......)
我花了很多时间甚至想过改变接收器,但我认为它不会改变任何东西,因为它发生在没有它但更少的情况下。
在这篇文章中抱怨的所有人呢?
我意识到最近没有人写过,英特尔没有解决它
如果我从NUC7i5BNH改为NUC7i7BNH,它会解决吗?
谢谢
以上来自于谷歌翻译
以下为原文
The nuc is completely new, connected to receiver with hdmi 2.0 cables 4k(60Hz). I also tried 4
different 4k cables (the receiver has 3 hdcp 2.2 port, it connected to
port 1)
from the receiver it connected to projector with hdmi 2.0 cables for
4k(60Hz)I also tried different 4k cables-short, long. the projector has
only one input for hdcp 2.2 so I connect it to this port.
The nuc is working ok when connecting strait to hd tv (not 4k), but not when
the receiver involved its flickering much.
When connecting it strait to projector there is less flickering but still
there is some and it can drop screen-then I have to restart.
In chrome browser it can happen but much less then Netflix app or Microsoft
edge.
YouTube and other website is always working perfect(hd,4k,hdr….)
I have also tested a 6th gen nuc from friend and it works fine.
I also have a 10 year old pc that work perfect with projector and receiver (win
7 connected the same way hdmi….)
I spent many hours and even thought changing the receiver but I think It
will not change anything because it happens without it but less.
What about all the people who complained in this post?
I realize that no one wrote lately and Intel didn’t solve it
If I change from NUC7i5BNH to NUC7i7BNH will it solve it?
thank you
在这篇文章中抱怨的所有人呢?
谢谢
以上来自于谷歌翻译
以下为原文
port 1)
edge.
thank you
