赛灵思
蔡鼎瑾
7年用户 1007经验值
Centos 5 Linux环境中没有检测到电缆
您好
我在Cemtos 5上安装了Xilinx EDKpackage
我拥有正确的许可驱动器等等。
当插入Spartan 6板时,会检测到电路
它不仅仅是一个电路板冲击返回,没有检测到电缆。
有什么我需要添加像设备规则,或特别是任何东西
以上来自于谷歌翻译
以下为原文
HI
I have installed Xilinx EDK package on Cemtos 5
i have everything set right with licensing cable drivers ect.
When plug in a Spartan 6 board the board does get detected
its not just one board impact returns that there is no cable detected.
Is there something i need to add like Device rules,or anything in particular
回帖(3)
吴觅
2018-11-14 10:45:01
您是否下载了驱动程序,运行安装脚本,然后更改windrvr6上的权限?
如果我没弄错的话,关于如何在Linux上安装电缆的.pdf忘记提及许可变更要求,但它在驱动程序的自述文件中列出。
以上来自于谷歌翻译
以下为原文
Did you download the driver, run the install script, and then change the permissions on the windrvr6? If I'm not mistaken, the .pdf on how to install the cables on Linux forgets to mention the permission change requirment, but it's listed in the readme with the driver.
刘伟
2018-11-14 10:53:37
请你发布指南和驱动程序下载的链接。
你能告诉我一个与ISE一起安装电缆驱动器的事情吗?你建议任何其他驱动程序
你正在谈论的是什么?
谢谢
以上来自于谷歌翻译
以下为原文
can you please post the links to the guide and driver downloads.
can you tell me one more thing the cable drivers are installed along with the ISE are you suggesting any other drivers
what are these permissions that you are talking about
Thank you
吴觅
2018-11-14 11:00:25
用户指南可在此处找到:
http://www.xilinx.com/support/documentation/user_guides/ug344.pdf
司机可以在这里找到:
https://secure.xilinx.com/webreg/clickthrough.do?cid=103670
在上述位置下载的存档中,您将找到一个自述文件,其中提供了在Linux上安装所需的说明。
我建议忽略上面的用户指南,因为在检查后,我可以确认它不会告诉您重置权限。
以上来自于谷歌翻译
以下为原文
The user guide is found here:
The drivers can be found here:
In the archive downloaded at the above location you'll find a readme file that gives the directions you need to install on Linux. I suggest ignoring the user guide above since, after checking, I can confirm it doesn't tell you to reset permissions.
