Cypress技术论坛
李泓翔
7年用户 210经验值
是否能重新编程CY8CKIT-059 Kitprog板载编程器?
我想知道是否有可能重新编程CY8CKIT-059 KITPROG车载编程?
我已经查看了“工具箱指南”数据表(第38页)中的示意图,我看不到任何程序引脚。
多谢
本赫
以上来自于百度翻译
     以下为原文
  I was wondering if it's possible to re-program the CY8CKIT-059 Kitprog on-board Programmer?
I've looked at the schematic in the 'Kit Guide' datasheet (page 38) and I can't see any programming pins routed out.
Many thanks
BenH
回帖(5)
付雯瑶
2018-11-13 17:08:47
你到底是什么意思重新编程KiPrg?
以上来自于百度翻译
     以下为原文
  Just what do you mean by reprogramming Kitprog?
李泓翔
2018-11-13 17:15:35
引用: 蔡R2016 发表于 2018-11-13 07:56
你到底是什么意思重新编程KiPrg?
以上来自于百度翻译
CY8CKIT-059有一个内置但可拆卸的程序员。我想知道这个程序员是否可以被重新编程,当它脱离主板时做别的事情。它有一些IO路由出去,一定是出于某种原因。
以上来自于百度翻译
     以下为原文
  The CY8CKIT-059  has a built-in but detachable programmer. I was wondering if this programmer can be reprogrammed to do something else once it has been detached from the main board. It has some IO routed out which must have been done for a reason.
付雯瑶
2018-11-13 17:33:51
编程头具有PSoC 5部分号CY8C5868 LTI-LP039 QFN68。你可以用它作为PSoC 5并像目标板一样编程。注意一些线路上的通行证。由于这个特性,您有能力将您自己的PSoC 5LP代码引导到设备中。通过这样做,您可以覆盖自定义项目的现有PSoC 5LP功能。不要担心重写PSoC 5LP代码,您可以轻松地将PSoC 5LP还原为其工厂设置,作为程序员和调试器。此引导加载程序允许您尝试PSoC 5LP设备,并使您的先锋工具包成为双臂开发平台。看到它的PSoC 4板,但它是相同的为您的董事会www. com /Cultuth/Trabe/25084/L/PSOC-4先锋- KIT-Cultudio项目036WAT-I CAN-USE-PSOC-5LP-太
以上来自于百度翻译
     以下为原文
  The programming header has a PSOC 5 part number CY8C5868LTI-LP039 QFN68. You can use this as a PSOC 5 and program it just like the target board. Watch out for By-pass caps on some of the lines. . Due to this feature you have the ability to bootload your own custom PSoC 5LP code into the device. By doing this you overwrite the existing PSoC 5LP functionality for your custom project. Don’t worry about overwriting the PSoC 5LP code, you can easily restore the PSoC 5LP to its factory setting as a programmer and debugger. This bootloader allows you the opportunity to try out the PSoC 5LP device and enable your Pioneer kit as a dual ARM development platform. See this its for the PSOC 4 board but it's the same for your board www.element14.com/community/thread/25084/l/psoc-4-pioneer-kit-community-project036-what-i-can-use-the-psoc-5lp-too
李恩佳
2018-11-13 17:41:24
引用: 蔡R2016 发表于 2018-11-13 08:21
编程头具有PSoC 5部分号CY8C5868 LTI-LP039 QFN68。你可以用它作为PSoC 5并像目标板一样编程。注意一些线路上的通行证。由于这个特性,您有能力将您自己的PSoC 5LP代码引导到设备中。通过这样做,您可以覆盖自定义项目的现有PSoC 5LP功能。不要担心重写PSoC 5LP代码,您可以轻松地将PSoC 5LP还原为其工厂设置,作为程序员和 ...
我必须用显微镜。
我这样做了:
以上来自于百度翻译
     以下为原文
  I had to use a microscope.
I did this:
