英特尔
李子邯
8年用户 177经验值
BOXNUC7I3BNK将EVO 970视为Legacy而非UEFI
有一个新的BOXNUC7I3BNK NUC套件。
仅使用三星EVO 970 M.2 ssd。
BIOS将驱动器识别为M.2 ssd,但是
在启动面板中,不会将其识别为UEFI驱动器,仅作为Legacy驱动器。
我更新了最新的Bios,之后是针对Windows 10系统的英特尔支持文章000022600(5-11-18)。
第3项子项C说“在引导>引导配置菜单中,在UEFI引导窗格中,OS选择设置为
Windows 8.x / Windows 10“。我的Bios在UEFI引导窗格中没有OS选择选项。
请告诉我,我错过了什么。
提前致谢。
以上来自于谷歌翻译
以下为原文
Got a new BOXNUC7I3BNK NUC Kit.  Only using a Samsung EVO 970 M.2 ssd.  The bios recognized the drive as an M.2 ssd, but
in the boot panel, does not recognize it as a UEFI drive, only as a Legacy drive.
I updated to the most recent Bios, followed an Intel support article 000022600 (5-11-18) for Windows 10 system.
Item 3 sub item C says to "On the Boot > Boot Configuration menu, in the UEFI boot pane, OS Selection is set to
Windows 8.x/Windows 10".  My Bios does not have an OS Selection option in the UEFI boot pane.
Please tell me I am missing something.
Thanks in advance.
回帖(2)
汤宇
2018-11-7 11:17:24
你好,sucko。
非常感谢您加入英特尔社区。我想澄清一下:您是否能够从启用了UEFI启动的驱动器启动?然后,您是否尝试过在UEFI启动中将SSD测试到另一个系统?
此外,您的M.2 SSD的部件号是多少?如果您可以共享英特尔®视频BIOS的Home和Boot页面的屏幕截图,我将非常感谢.Antony S.
以上来自于谷歌翻译
以下为原文
Hello, sucko Thank you very much for joining the Intel Community.
I would like to clarify: Are you able to boot from the drive with UEFI boot enabled?
Then, have you tried testing the SSD into a different system in UEFI Boot? Additionally, what is the part number of your M.2 SSD?
I would highly appreciate if you can share a screenshot of the Home and Boot pages of the Intel® Visual BIOS.
Antony S.
李玉鑫
2018-11-7 11:30:25
你好,sucko。我想知道你是否还需要帮助。
如果是这样,请不要犹豫回复此主题.Antony S.Intel客户支持技术人员与英特尔公司签订合同
以上来自于谷歌翻译
以下为原文
Hello, sucko
I would like to know if you still need assistance. If so, do not hesitate in replying to this thread.
Antony S.
Intel Customer Support Technician
Under Contract to Intel Corporation
