$ ./flashall.shThe normal flashing did not work, so I tried the recovery option:
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
Timed out while waiting for dfu device 8087:0a99
DEBUG: lsu***
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 138a:0090 Validity Sensors, Inc.
Bus 001 Device 003: ID 04f2:b52c Chicony Electronics Co., Ltd
Bus 001 Device 005: ID 8087:0a2b Intel Corp.
Bus 001 Device 057: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
DEBUG: dfu-util -l
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Did you plug and reboot your board?
If yes, please try a recovery by calling this script with the --recovery option
$ ./flashall.sh --recoverySo there was no success either. I figured I should try a serial connect:
Starting Recovery mode
Flashing IFWI
XFSTK Downloader Solo 1.8.1-5.1
Copyright (c) 2015 Intel Corporation
Build date and time: Sep 1 2017 15:13:00
Intel SoC Device Detection Failed: Attempt #0
Intel SoC Device Detection Failed: Attempt #1
Intel SoC Device Detection Failed: Attempt #2
Intel SoC Device Detection Failed: Attempt #3
Intel SoC Device Detection Failed: Attempt #4
Intel SoC Device Detection Failed: Attempt #5
Intel SoC Device Detection Failed: Attempt #6
Intel SoC Device Detection Failed: Attempt #7
Intel SoC Device Detection Failed: Attempt #8
Intel SoC Device Detection Failed: Attempt #9
Intel SoC Device Detection Failed: Attempt #10
Intel SoC Device Detection Failed: Attempt #11
Intel SoC Device Detection Failed: Attempt #12
Intel SoC Device Detection Failed: Attempt #13
Intel SoC Device Detection Failed: Attempt #14
Intel SoC Device Detection Failed: Attempt #15
Intel SoC Device Detection Failed: Attempt #16
Intel SoC Device Detection Failed: Attempt #17
Intel SoC Device Detection Failed: Attempt #18
Intel SoC Device Detection Failed: Attempt #19
Intel SoC Device Detection Failed: Attempt #20
Xfstk tool error
DEBUG: lsu***
DEBUG: dfu-util -l
dfu-util 0.9
$sudo screen /dev/ttyUSB0So there is something coming from the Edison upon reboot... Every time I reset the Edison, this line of garbage is being received again...
4DE���}��D��E����u�5�d��ZR��Z��~���g�����gZ�cWs�gK�f�s��SgR�s�~�os{k����K
引用: jerry1978 发表于 2018-11-2 14:08
嗨,Christian,感谢您对英特尔Edison套件的兴趣。如果您按照以下链接中的步骤,请告诉我们。
:https://www.intel.com/content/www/us/en/support/articles/000006285/boards-and-kits.html您还可以尝试使用FlashToolLite来刷新英特尔Edison Board上的最新固件:https
://01.org/node/2463如果您有其他问题,请告诉我 ...
$ sudo screen /dev/ttyUSB0 115200So I connected J16 to an external power supply and J3 to a USB port on my computer. Then I see the following:
PSH KERNEL VERSION: b0182b2b
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 11:24:08 Feb 5 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
WR: 20104000
WR: 20104000
WR: 20104000
So it just hangs when the kernel is supposed to be started...
WR: 20104000
U-Boot 2014.04 (Jun 06 2016 - 14:40:07)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Target:blank
Partitioning already done...
Flashing already done...
GADGET DRIVER: u***_dnl_dfu
reading vmlinuz
5461344 bytes read in 135 ms (38.6 MiB/s)
Valid Boot Flag
Setup Size = 0x00003c00
Magic signature found
Using boot protocol version 2.0c
Linux kernel version 3.10.98-poky-edison+ (neck@flax) #1 SMP PREEMPT Mon Jun 6 14:32:08 PDT 2016
Building boot_params at 0x00090000
Loading bzImage at address 00100000 (5445984 bytes)
Kernel command line: "rootwait root=PARTUUID=012b3303-34ac-284d-99b4-34e03a2335f4 rootfstype=ext4 console=ttyMFD2 earlyprintk=ttyMFD2,keep loglevel=4 g_multi.ethernet_config=cdc systemd.unit=multi-user.target hardware_id=00 g_multi.iSerialNumber=a4015fb9e5c0de59334eaaf4e10feb92 g_multi.dev_addr=02:00:86:0f:eb:92 platform_mrfld_audio.audio_codec=dummy"
Starting kernel ...
引用: cd340823 发表于 2018-11-2 14:22
是的,我按照这些步骤操作,它已在步骤2中失败。
如果我将两根电缆连接到我的电脑并调用屏幕,我会得到一个重启循环。
我想这是由于USB端口的电量不足:
引用: jerry1978 发表于 2018-11-2 14:41
您好Christian,我们非常感谢您能否为我们提供以下问题的答案:最后一次董事会工作时间是什么时候?是否有任何外部传感器连接?任何可以帮助我们识别问题的其他信息将非常感谢
。我们还建议您通过网上门票提交保修申请。退休,乔治
