Cypress技术论坛
马昱
7年用户 229经验值
CX3帧率怎么控制
我想通过USB控制来制作具有可变帧速率的UVC相机。然而,AN7799如何在USB视频类(UVC)框架中使用EZ-USB®FX3μ来实现图像传感器接口,帧速率被定义为相机的常数。
我有一个外部微控制器来控制帧速率。不是用UVC来控制帧速率,而是用FVAL信号来控制帧速率?
(例如,传感器每20-30毫秒开始FVAL,这意味着33-50fps,但定义的UVC帧速率是60 fps,对于系统来说,我能得到33-50fps吗?)
以上来自于百度翻译
     以下为原文
  I want to make a UVC camera with changable frame rate via USB Control. However, AN75779 How to Implement an Image Sensor Interface Using EZ-USB® FX3™ in a USB Video Class (UVC) Framework example, frame rate is defined and constant for camera.
I have a external microcontroller to control frame rate. Can I control the frame rate not by uvc but only fval signal of sensor?
(For example sensor starts fval in every 20-30 ms which means that 33-50 fps but defined uvc frame rate is 60 fps can I get 33-50 fps for system or not?)
