您好strajerry,感谢您联系英特尔®技术支持。据我们了解,您需要有关英特尔®SSD600p系列(128GB)的帮助。
如果我们正确推断,开始诊断和随后的故障排除可能需要我们解决,我们将不胜感激,如果可以的话,请回复此帖,其中包含以下重要的基本信息:SSU日志.-转到
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?v=t并下载软件.2-下载完成后,打开它.3-标记“Everything”框,然后
单击“扫描4.-完成扫描后,单击”下一步。“5-单击”保存“.6-将文件附加到您的回复中。
窗口“磁盘管理”的屏幕截图显示了所有硬盘和分区。
窗口“设备管理器”的屏幕截图显示了您的所有硬件。我们期待您的回复。最好的问候,JoshB.Intel®客户支持技术人员与英特尔公司的合同
以上来自于谷歌翻译
以下为原文
Hello strajerry,
Thank you for contacting Intel® Technical Support.
As we understand, you need assistance with your Intel® SSD 600p Series (128GB). If we infer correctly, to begin diagnosis and consequent troubleshooting that could take us to a resolution, and we would appreciate if you could, please, reply to this post with the following, important, basic information:
The SSU logs.
1- Go to
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility?v=t and download the software.
2- When finished downloading it, open it.
3- Mark the box "Everything" and then click "Scan.
4- When finish scanning, click "Next."
5- Click on "Save."
6- Attach the file to your reply.
- A screenshot of the “Disk Management” of windows showing all your HDDs and partitions.
- A screenshot of the “Device Manager” of windows showing all your hardware.
We will be looking forward to your reply.
Best regards,
Josh B.
Intel® Customer Support Technician
Under Contract to Intel Corporation
以上来自于谷歌翻译
以下为原文
Hello strajerry,
The SSU logs.
1- Go to
5- Click on "Save."
Best regards,
Josh B.
