我在NUC6i7KYK(骷髅峡谷)中安装了新的1TB Intel 760p驱动器作为第二个M2驱动器。
BIOS看到了合适尺寸的第二个驱动器,但认为它是第二个三星960 Pro。
我认为这是一些bios问题,可能无法从第二个M2驱动器正确读取制造商代码。
但是,如果这是一个问题,我不想再往前走了。
有人见过这个吗?
以上来自于谷歌翻译
以下为原文
I installed a new 1TB Intel 760p drive as the second M2 drive in NUC6i7KYK (Skull Canyon). The bios sees the second drive of the right size, but thinks it is a second Samsung 960 Pro.
I presume this is some bios problem, probably not reading the manufacturer code correctly from the second M2 drive.
However, I don't want to go further if this is going to be a problem.
Anyone seen this already?
