你好,我有一个1680A的Adlink M-815G主板。
它运行Win XP SP2和LA软件版本3.67没有任何问题。
我想将它升级到Win XP SP3,这样我就可以运行更高版本的LA软件(5.70)。
不幸的是,当我尝试安装SP3补丁时,出现了问题,分析仪将不再启动。
然后我安装了一个新的Win XP SP3副本,分析仪启动到Windows,但内部LCD显示器没有激活,我可以使用分析仪的唯一方法是使用外部显示器。
最后,我从Keysight FTP站点(01680-14106)下载了恢复CD映像文件,虽然它们似乎已经恢复了硬盘驱动器,但一旦恢复完成,分析器只能获得初始磁盘检查例程,然后
停滞在“准备启动Windows”消息。
我重复了这个过程,重新下载了恢复映像但得到了相同的结果。
顺便说一句,这似乎与他在2009年7月24日在“示波器/一般用法”
论坛上关于他自己的1680A恢复过程的帖子中描述的“tonykara”相同。
问题:1)我是否遗漏了CD恢复过程中的内容?
我按照“书”做了一切,但s
til无法使分析仪正常启动。
2)有没有办法启用内部LCD,以便我可以使用我的OEM Windows XP SP3安装盘并从那里开始?
我想如果我能将内置LCD作为主要显示器,我可以安装LA软件并完成。
谢谢,新年快乐!
斯坦
以上来自于谷歌翻译
以下为原文
Hello,
I have a 1680A with the Adlink M-815G motherboard. It was running Win XP SP2 and LA software version 3.67 with no problems. I wanted to upgrade it to Win XP SP3 so I could run a later version of the LA software (5.70). Unfortunately, when I tried to install the SP3 patch, something went wrong and the analyzer would no longer boot.
I then installed a fresh copy of Win XP SP3, and the analyzer booted up fine into Windows, but the internal LCD display was not active, and the only way I could use the analyzer was with an external display.
Finally, I downloaded the restore CD image files from the Keysight FTP site (01680-14106), and although they appeared to have restored the hard drive, once the restore was completed the analyzer got only as far as the initial disk check routine, then stalled at "Getting ready to start Windows" message. I repeated the process with fresh downloads of the restore images but got the same result. BTW, this appears to be the same problem as "tonykara" described in his posting on 7/24/09 in the "Oscilloscopes/General Usage" forum about his own 1680A restore process.
Questions:
1) Am I missing something with the CD restore process? I did everythhing "by the book" but stil can't get the analyzer to boot properly.
2) Is there a way to enable the internal LCD so I can use my OEM Windows XP SP3 install disk and go from there? I think if I could get the internal LCD to be the primary display, I could just install the LA software and be done.
Thanks and Happy New Year!
Stan
