有两种配置,你可以做到:要点是把你的PC和PIC放在同一子网下。1)把静态IP分配给你的以太网卡:你可以从Windows控制面板上做,你必须把你的IP放在微控制器的同一子网下。EX:如果分配给PIC的IP是192.168100.10,那么你必须给你的PC的IP是192.168100.x(EX:X=15),子网掩码是255.255.255.0和网关192.168100.1。然后,你必须打开你的浏览器并输入PIC的IP。2)让PIC从DHCP服务器请求一个动态IP:在这个配置中,PIC必须配置为DHCP客户端,你不必对你的PC以太网卡进行控制,把它放在动态IP上,但是你必须使用一个路由器。图中的路由器,并连接您的PC和PIC到路由器的局域网端口。然后,你必须进入路由器配置来检查PIC的IP,然后,你可以从你的浏览器中启动PIC的IP。对于和谐的配置,我遵循TCP/IP硕士课程PDF的微芯片。谢谢。
以上来自于百度翻译
以下为原文
There are two configurations that you can do:
The point is to put your PC and the PIC under the same subnet.
1) Assign Static IP to your ethernet card:
You can do it from control panel from windows and you have to put your IP under the same subnet of the microcontroller. ex: if the IP assigned to the PIC is 192.168.100.10, the ip that you have to give to your PC is 192.168.100.x (ex: x=15), subnet mask is 255.255.255.0 and the gateway 192.168.100.1 . Then, you have to open your browser and enter the IP of the PIC. (disable any other network connection first like wifi,..etc).
2) Let the PIC ask for a dynamic IP from DHCP server:
In this configuration the PIC have to be configured as DHCP client, you don't have to cinfigure your PC ethernet card, leave it on Dynamic IP, but you have to use a router.
You have to configure the router and connect your PC and the PIC to the LAN ports of the router. Then, you have to enter to the router configration to check the IP of the PIC and then, you can proceed from your browser, enetering the PIC's IP.
For the configuration of the HARMONY, i followed the TCP/IP master course PDF of MICROCHIP.
Thanks.
以上来自于百度翻译
以下为原文
Thanks.
