嗨大卫,
感谢您的回复,我已经将arduino uno board连接到了
X-NUCLEO-IKS01A1如图所示。我也连接了电路板
X-细胞核 - IKS01A1
对于Vin作为5V。我已经通过给SCL和SDA提供3.3V来增加上拉电阻。但是在arduino控制台中我无法看到任何输出。即使我也尝试过英特尔爱迪生,设备地址也没有检测到。我用来检查的代码是
https://github.com/ControlEverythingCommunity/LPS25HB/blob/master/Arduino/LPS25HB.ino
https://github.com/ControlEverythingCommunity/HTS221/blob/master/Arduino/HTS221.ino
请你需要。我也不知道跳线设置。我不知道错误在哪里?!!
感谢致敬,
镭
dhika
以上来自于谷歌翻译
以下为原文
Hi David,
Thanks for the reply,I have connected the arduino uno board with
X-NUCLEO-IKS01A1 as shown in the image.I have also connected the board
X-NUCLEO-IKS01A1
for Vin as 5V.I have added pull up resisters too by giving 3.3V to SCL and SDA.But in arduino console I'm unable to see any output. Even I have tried in Intel edison too,the device address is not detecting.The codes I'm using to check is
Please do needful.I'm not knowing the jumper settings too.I'm not knowing where the mistake is?!!
Thanks and Regards,
Ra
dhika
嗨大卫,
X-细胞核 - IKS01A1
感谢致敬,
镭
dhika
以上来自于谷歌翻译
以下为原文
Hi David,
X-NUCLEO-IKS01A1
Thanks and Regards,
Ra
dhika
