哪种型号的范围?
什么版本的SW?
答案在某种程度上取决于了解这一点
在Infiniium示波器上,通常,存储的数据(包括.bin)被加载到存储器波形中。
根据SW版本,您可以执行以下操作:右键单击波形以访问缩放控件,或使用下拉菜单执行相同操作。
在某些版本中,您可以将m1波形附加到通道1控件,因此转动垂直旋钮将进行垂直缩放。
您还可以将存储器波形绑定到示波器水平控件,因此转动水平旋钮将更改时间刻度。
免责声明:为了获得更可靠的响应,您应该考虑致电当地的Keysight技术呼叫中心。
Keysight论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。
以上来自于谷歌翻译
以下为原文
Which model of scope? What version of SW?
The answer somewhat depends on knowing this.
On Infiniium scopes, in general, stored data (including .bin) is loaded into a memory waveform. Depending on the SW version, you can do things like right-click on the waveform to get access to the scaling controls, or use a pull-down menu for the same things. On some versions you can attach, for instance, the m1 waveform to the Channel 1 controls so turning the vertical knobs will do vertical scaling. You can also tie the memory waveforms to the scope horizontal controls, so turning the horizontal knob will change the time scale.
Al
Disclaimer: For more reliable response, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered.
哪种型号的范围?
什么版本的SW?
答案在某种程度上取决于了解这一点
以上来自于谷歌翻译
以下为原文
Al
