英伟达
石双厚
8年用户 195经验值
GRID软件为2016 Hyper-V环境提供了什么价值?
关于这一点的信息似乎有限,营销材料让事情变得更加混乱,所以我想我会希望得到一个明确的答案。
甚至没有一个部署指南让我相信它提供有限的或没有价值。
与VMWare不同,Hyper-V上的GRID不允许仅在VM中加载本地NVIDIA驱动程序RemoteFX,对吗?
我可以使用DDA并切断GPU并将其分配给VM,但我可以在没有GRID的情况下执行此操作,对吗?
我真的不想尝试重击GRID,只是它似乎没有提供它在VMWare或Citrix中的价值。
有人可以让我知道在Hyper-V(裸机)上使用GRID与仅使用Windows Server 2016提供的本机RemoteFX和/或DDA相比的优势吗?
谢谢
以上来自于谷歌翻译
以下为原文
There seems to be limited information on this, and the marketing material makes things more confusing so I thought I would post in hopes to get a definitive answer.
What value does GRID software provide to a 2016 Hyper-V environment?  There isn't even a deployment guide for which lets me believe it provides limited or no value.  Unlike in VMWare, GRID on Hyper-V does not allow loading of local NVIDIA drivers in a VM only RemoteFX, correct?  I can use DDA and carve off a GPU and assign it to a VM, but I can do this without GRID, correct?  I really am not trying to bash GRID, just it does not seem to provide the value it does in VMWare or Citrix.  Can someone please let me know the advantages of using GRID on Hyper-V (bare metal) vs just using native RemoteFX and/or DDA that Windows Server 2016 provides?
Thanks
回帖(4)
萧登水
2018-9-19 17:08:45
同样的问题,我是否需要在2016年Hyper-V服务器上使用Remote FX vGPU的虚拟RDS服务器的Grid Software许可证?
以上来自于谷歌翻译
以下为原文
Same question here, do i need the Grid Software license for a virtual RDS server with Remote FX vGPU on a Hyper-V server 2016?
王鹏
2018-9-19 17:14:15
答案是肯定的,您需要为在RDSH上运行的每个用户提供vApp许可证。
DDA是GPU Passthrough,您拥有VM中的本机NV驱动程序,具有所有优势。
使用RemoteFX,您有一个基于拦截的软件驱动程序,但有一些限制。
我同意在Hyper-V上运行GRID通常没有多大意义,因为您无法使用vGPU,因此您无法获得所需的密度,尤其是VDI部署。
问候
西蒙
以上来自于谷歌翻译
以下为原文
The answer is Yes you need a vApps license for each user running on the RDSH.
DDA is GPU Passthrough and you have the native NV drivers within the VM with all advantages. With RemoteFX you have an interception based software driver with some limitations.
I agree that it often makes not much sense to run GRID on Hyper-V as you cannot use vGPU and therefore you don't get the required density especially for VDI deployment.
Regards
Simon
刘甜甜
2018-9-19 17:27:44
我是否可以使用没有GRID软件许可证的Nvidia Tesla M10作为vGPU与RemoteFX一起用于Hyper-V上的Windows Server 2016远程桌面服务器?
以上来自于谷歌翻译
以下为原文
Can i use the Nvidia Tesla M10 without GRID software license to be used as vGPU with RemoteFX for my Windows Server 2016 Remote Desktop server on Hyper-V?
李桂芝
2018-9-19 17:33:28
DDA是2016 Hyper-V的功能,而不是GRID的功能。
因此,您可以在没有GRID的情况下使用DDA并在VM中加载本机驱动程序,它将显示所有性能优势。
我没有任何vApp经验,但在Windows Server RDSH上本身没有硬件加速,但vApp是否将此添加到Windows?
如果NVIDIA提供真实的文档而不仅仅是营销材料,将会有所帮助。
@sschaber:您是使用Hyper-V(裸机)与RDSH和vApp,还是使用不同的虚拟机管理程序与Windows RDSH作为VM运行?
以上来自于谷歌翻译
以下为原文
DDA is a function of 2016 Hyper-V and not of GRID.  So you can use DDA and load native drivers in the VM without GRID and it will show all the performance benefits.  I have not had any experience with vApps, but natively on Windows Server RDSH there is no hardware acceleration, but does vApps add this to Windows?  Would be helpful if NVIDIA provided real documentation and not just marketing material.
@sschaber: Are you using Hyper-V (bare metal) with RDSH and vApps, or using a different hypervisor with Windows RDSH running as a VM?
