英伟达
秦伙茂
8年用户 188经验值
Xenserver 7.1 Windows 10使用驱动程序369.95构建1703蓝屏
这是我在这里的第一篇文章,所以提前感谢您提供的任何帮助。
我的组织正在运行Xenserver 7.1,目前有140个支持Grid vGPU的dektop运行Windows 7.我们正在迁移到Windows 10和Office 2016,但是我遇到了在Windows 10企业版中安装最新版本的369.95驱动程序的问题
驱动程序包正常安装,但是一旦执行重新启动,我就会在dxgkrnl.sys上看到系统异常的蓝屏。
这是一个已知的问题?
我假设它的驱动程序与此特定版本的Windows相关,因为使用Windows 10 LTSB build 1607根本没有驱动程序问题。
以上来自于谷歌翻译
以下为原文
This is my first post here, so thanks in advance for any help you can provide.
My organization is running Xenserver 7.1 and currently has 140 Grid vGPU enabled dektops running Windows 7. We are in the process of moving to Windows 10 and Office 2016, but I am having issues with getting 369.95 drivers installed in the latest build if Windows 10 Enterprise. The driver package installs normally, but as soon as a reboot is executed I get a blue screen for a system exception at dxgkrnl.sys.
Is this a known issue? I'm assuming it's driver related with this particular build of Windows, because using Windows 10 LTSB build 1607 has no issues with the drivers at all.
回帖(5)
h1654155275.5748
2018-9-18 16:41:35
嗨杰克
欢迎来到论坛!
我还没有使用过1703,所以刚刚从Technet上下载了一个评估版,并在我的实验室中试过......我在重启时也遇到了崩溃(同样的XenServer和GRID版本)。
驱动程序安装正常,重启并崩溃。
我的建议,暂时坚持使用1607 LTSB,它经过测试和稳定,仍然可以从Win 7提供良好的体验/安全升级。然后将“创建者更新”应用到您的1607基础或创建新的1703基础时
经过验证并且稳定。
只是阅读其他论坛,1703还有其他GPU问题......
我会向GRID团队提出这个问题,以便他们知道。
问候
以上来自于谷歌翻译
以下为原文
Hi Jake
Welcome to the forum!
I've not used 1703 yet, so just downloaded an evaluation from Technet and tried in my lab ... I get a crash at reboot too (same XenServer and GRID versions). Driver installs fine, reboot and it crashes. My advice, stick with 1607 LTSB for the time being, it's tested and stable and will still provide a nice experience / security upgrade from Win 7. Then either apply that "creators update" to your 1607 base or create a new 1703 base when it's been validated and is stable.
Just reading other forums, there are other GPU issues with 1703 as well ...
I'll raise it with the GRID team so they're aware.
Regards
Ben
刘婷婷
2018-9-18 17:01:05
嗨伙计
我也有同样的问题。
我用一台Tesla M60设置了一个新的XenServer 7.1主机。
Citrix XenDesktop 7.13提供对Windows 10虚拟机的访问。
所有Windows 10 v1607计算机都运行正常,但是当每次启动时安装了Grid驱动程序369.95并显示“SYSTEM THREAD EXCEPTION NOT HANDLED”时v1703崩溃。
我发现它与虚拟机的屏幕分辨率有关。
我在XenServer中使用GRID M60-2Q(4显示,4k Res)配置文件。
如果安装Grid驱动程序,屏幕分辨率将切换为2560 * 1600。
只要不重新启动Windows vm,就可以使用它。
如果你重新启动,你会得到BSOD。
您可以通过在XenCenter中选择另一个GPU配置文件来“修复”您的计算机,该配置文件不允许高于全高清的分辨率,1920 * 1200似乎是最大工作设置。
您可能需要多次重新启动虚拟机,直到Windows 10自动进行自我修复。
只要在重新启动机器之前设置不超过1920 * 1200的分辨率,就可以切换回更高分辨率的配置文件。
我还测试过通过XenDesktop连接到机器。
由于我目前最多使用三个全高清显示器,我切换到跨越所有三个显示器的全屏桌面,这很好。
我希望这有助于解决这个问题。
我们还有一些内置4k显示器的笔记本电脑,将来可能需要访问这些机器。
问候,
勒内
以上来自于谷歌翻译
以下为原文
Hi Folks
I have the same problem. I set up a new XenServer 7.1 host with one Tesla M60. Citrix XenDesktop 7.13 provides access to Windows 10 virtual machines. All Windows 10 v1607 machines are running fine, but v1703 crashes when the Grid driver 369.95 is installed on every boot showing "SYSTEM THREAD EXCEPTION NOT HANDLED".
I figured out it has something to do with the screen resolution of the virtual machine. I'm using the GRID M60-2Q (4 displays, 4k Res) profile in XenServer. If you install the Grid driver the screen resolution switches to 2560*1600. You can work with this as long as you do not reboot the Windows vm. If you restart you get the BSOD. You can "fix" your machine by choosing another GPU profile in XenCenter which does not allow resolution higher than Full HD, 1920*1200 seems to be the maximum working setting. You may have to restart the virtual machine several times until Windows 10 automatically repairs itself.
You can switch back to higher resolution profiles as long as you set a resolution not exceeding 1920*1200 before you restart the machine.
I also tested to connect to the machine via XenDesktop. As I'm using a maximum of three Full HD displays at the moment, I switched to a full screen desktop spanning all three displays, which works fine.
I hope this will help to fix the issue. We also have some laptops with builtin 4k displays, which may need access to these machines in the future.
Regards,
René
王竹
2018-9-18 17:13:45
嗨,大家好,
由于Win10 v1703在当前的GRID版本之后出现,因此未经过测试/支持。
请继续使用v1607,直到有下一个支持1703的GRID版本。
问候
西蒙
以上来自于谷歌翻译
以下为原文
Hi guys,
as Win10 v1703 came out after the current GRID version it is not tested/supported. Please stay with v1607 until there is the next GRID release with support for 1703.
Regards
Simon
周莹
2018-9-18 17:20:56
嗨伙计,
只想更新您使用MSFT修补程序解决此问题:
https://www.catalog.update.microsoft.com/Search.aspx?q=KB4020102
问候
西蒙
以上来自于谷歌翻译
以下为原文
Hi folks,
just want to update you that this issue is solved with a MSFT hotfix:
Regards
Simon
