ST意法半导体
乔银栓
8年用户 249经验值
Acc的顺序抗混叠滤波器是什么?
我有几个问题。
1. Acc的顺序抗混叠滤波器是什么?
2.陀螺的顺序抗混叠滤波器是什么?
3.如果截止频率高于nyquist频率,DLPF1滤波器如何帮助我?
谢谢,
阿米尔
#lsm6ds3#lsm6ds3
以上来自于谷歌翻译
以下为原文
hi,
I've got a few questions.
1. what is the order anti-aliasing filter of the Acc?
2. what is the order anti-aliasing filter of the Gyro?
3. how does the DLPF1 filter help me if the cut-off freq is higher then nyquist freq?
thank you,
amir
#lsm6ds3 #lsm6ds3
回帖(3)
王兵
2018-9-11 16:50:34
大家好,
 我对LSM9DS1有类似的问题:
 1.加速度ODR选择下降到10 Hz,但带宽选择(可能是抗混叠滤波器)限制为50Hz。因此,当在10Hz或50Hz下以50Hz的带宽选择进行采样时,预期会出现严重的混叠。有没有办法避免这种情况?
 2.没有正确记录加速度数字滤波器操作。 “高分辨率”指的是什么?如何选择LPF或HPF?
以上来自于谷歌翻译
以下为原文
Hi all,
I have similar questions regarding the LSM9DS1:
1. The Acceleration ODR choices go down to 10 Hz, however the bandwidth selection, presumable an anti-aliasing filter, is limited to 50Hz. Thus, when sampling at 10Hz or 50Hz with a bandwidth selection of 50Hz severe aliasing is to be expected. Is there a way to avoid this?
2. The accelerometed digital filter operation is not documented properly. What dow ''high resolution'' refer to? How is LPF or HPF selected?
周芳卿
2018-9-11 16:59:15
嗨阿米尔,
请参阅可从ST网页下载的AN4650应用说明的第2.6章和第2.7章:
http://www.st.com/resource/en/application_note/dm00157511.pdf
感谢你并致以真诚的问候,
切赫
以上来自于谷歌翻译
以下为原文
Hi Amir,
please refer to the Chapters 2.6 and 2.7 of the AN4650 Application Note downloadable from ST web pages:
Thank you and best regards,
Petr
李腈
2018-9-11 17:09:05
我没有看到AN4650中的那些章节,或者任何回答问题的章节:抗锯齿滤镜的顺序是什么。我还有一个问题:陀螺抗锯齿滤波器的截止频率和阶数是多少?
以上来自于谷歌翻译
以下为原文
I don't see those chapters in AN4650, or anything that answers the questions: what is the order of the antialias filters. I have another question: what is the cutoff frequency and order of the gyro antialias filter?
Dan
