谢谢你的回答。
我正在使用SDK版本1.3.4,我现在更新了它。
我发过去后不可能的配置,因为有一定的最小值为框架和行消隐。因此,我尝试了这个新的配置。我甚至放慢了FPS 15所以不会有任何问题。
事情是这样的,输出像素时钟的最小值大于最大值。这是因为V空白值高。此参数控制相机的FPS,所以如果它是低,FPS会很高,结果都是一样的。这是否意味着,CX3不能从这个摄像头读取数据?
我有降低相机的时钟频率的思想,这是唯一可能的解决办法?
我想尽量少改变相机的设置。
编辑:更新,我看到降低CSI时钟值不降低输出像素时钟的最小值。
我看不出解决的办法。希望得到帮助。
以上来自于百度翻译
以下为原文
Thanks for your answer.
I am using SDK version 1.3.4, I updated it right now.
The configuration I sent last post wasn't possible, since there are certain minimum values for frame and line blanking. Therefore, I tried this new configuration. I even slowed the FPS to 15 so there wouldn't be any problem.
The thing is, the Output Pixel Clock minimum value is above the maximum value. This is because the V blanking value is high. This parameter controls the FPS of the camera, so if it is low, the FPS would be high, and the result would be the same. Does this means that CX3 can't read data from this camera?
I have thought of reducing the camera clock frequency, is that the only possible solution?
I would like to change the camera settings as little as possible.
EDIT: Update, I see that lowering the CSI clock value does not reduce the minimum value of the Output Pixel Clock.
I don't see a solution. Help would be appreciated.
谢谢你的回答。
我想尽量少改变相机的设置。
我看不出解决的办法。希望得到帮助。
以上来自于百度翻译
以下为原文
