请确保您比新数据更快地从输出寄存器中读取数据。读取数据后应立即清除DRDY标志。您也可以将DRDY映射到INTx_DRDY中断引脚,并使用示波器或计数器在锁存或脉冲模式下观察它。见第8.6,8.7和8.41节
http://www.st.com/resource/en/datasheet/lsm303ah.pdf
以上来自于谷歌翻译
以下为原文
Please verify that you read the data from output registers fast enough, sooner than new data occur. DRDY flag should be cleared right after reading the data. You can also map the DRDY to INTx_DRDY interrupt pin and watch it using scope or counter in either latched or pulse mode. See sections 8.6, 8.7 and 8.41 in
以上来自于谷歌翻译
以下为原文
