英伟达
王桂珍
8年用户 160经验值
W10上的M60 vGPU不会安装驱动程序
嗨,我是vGPU配置的新手,但我正在尝试设置一套带有双M60的R730来在W10系统上托管多个4Q配置文件vGPU。
M60设置为“graphics”并安装了NVIDIA-vGPU-VMware_ESXi_6.0_Host_Driver_361.45.09-1OEM.600.0.0.2494585.vib。
可以选择配置文件,但在启动VM后,此“卡”不会显示在设备管理器中,也不能使用nvidia驱动程序。
有谁知道这个vGPU选项是否实际可用于W10?
谢谢 !
以上来自于谷歌翻译
以下为原文
Hi, I'm pretty new to vGPU configuration but I'm trying to setup a set of R730's with dual M60's to host multiple 4Q profiles vGPU's on W10 systems. M60's are set to "graphics" and has NVIDIA-vGPU-VMware_ESXi_6.0_Host_Driver_361.45.09-1OEM.600.0.0.2494585.vib installed. Profiles can be selected, but after starting the VM this "card" is not displayed in the device manager and no nvidia drivers can be used. Does anyone knows if this vGPU option is actually available for W10 ? Thanks !
陈晓露
2018-9-6 10:12:00
听起来好像你没有使用ESX的Enterprise Plus许可证。
您将无法使用标准的vGPU ...
以上来自于谷歌翻译
以下为原文
Sounds like you're not using Enterprise Plus license for ESX which is a requirement.
You won't be able to use vGPU with Standard...
