在第一次的cybt-343026-eval下载后,我无法下载cybt-343026-eval。
日志如下:
下载应用…
*********下载失败*************
|遵循下面的建议和重试。|
| 1。验证驱动程序是否正确安装| USB-UART
| 2。验证SW4开关在ON位置(CTS,RTS,RXD、TXD)|
| 3。动力循环cybt-343026-eval并重试。|
|如果此问题仍然存在,在板的串行闪存可能损坏。|
|遵循以下步骤重置到出厂默认状态cybt-343026-eval板。|
|注:这将删除内存中的任何用户应用和复位板dafulat状态|
| 1。按住按钮(SW2)|恢复
| 2。按住复位按钮(SW1)1二|
|三。|释放SW1
| 4。释放SW2 |
| 5。重新编程板|
下载失败。这WICED平台的SDK只支持下载20706a2装置。
19:43:08建完(带7s。653ms)
我试图复位cybt-343026-eval所起,但没有changed.wiced工作室Wi-Fi /组合
论坛”
以上来自于百度翻译
以下为原文
After download to the CYBT-343026-EVAL at the first
time,I can never download to CYBT-343026-EVAL.
Log as below:
Downloading application...
********* Download Failure *************
| Follow below suggestions and retry. |
| 1. Verify USB-UART driver is correctly installed |
| 2. Verify SW4 switches are in ON position (CTS, RTS, RXD, TXD) |
| 3. Power cycle CYBT-343026-EVAL and retry. |
| If this problem persists, the serial flash on the board may be corrupted. |
| Follow below steps to reset CYBT-343026-EVAL board to factory default state. |
| Note: This will erase any user applicaiton in the memory and reset the board to dafulat state |
| 1. Press and hold RECOVER button (SW2) |
| 2. Press and hold RESET button (SW1) for 1 second |
| 3. Release SW1 |
| 4. Release SW2 |
| 5. Re-program the board |
Download failed. This WICED platform of the SDK only supports download to 20706A2 device.
19:43:08 Build Finished (took 7s.653ms)
I tried to reset CYBT-343026-EVAL as up,but nothing changed.
WICED Studio Wi-Fi/Combo Forums@
