我看ADATE305的datasheet,ADATE同时具有驱动和比较的功能,我想请问一下,如果我从驱动切换到比较的状态,是不是要等很长时间??至少要写寄存器把驱动disable或者置成高阻状态呢?还是可以不用disable寄存器?
2018-8-18 07:57:10
Since you have forwarded your issue to below, the PL's engneer will reply to it
ADATE305 from drive to compare | EngineerZone
