TI论坛
王峰
7年用户 189经验值
cc3200 网页控制
网页控制cc3200
板子在AP模式下进入网页,将其修改成sta模式,sta连上 ssid为4499的wifi上 (重启之后生效这个过程应该怎么制作出来?)
将其设置为sta 设置连接到4499的wifi上 重启之后怎么让他自动连接到4499的wifi上呢?
回帖(3)
蒋美燕
2018-6-23 05:36:01
论坛有类似问题,请参考这边: https://www.deyisupport.com/question_answer/wireless_connectivity/wifi/f/105/t/81794.aspx
王峰
2018-6-23 05:50:03
我在网页上修改AP的名称和密码 我想重启后 AP设置为我网页上修改的那个
我应该怎么做呢?
重启后好像只有AP名称是上一次ap的  密码直接为open
我想重启后直接为上次ap的配置 包括密码
朱小玲
2018-6-23 05:59:03
我应该怎么做呢?
CC3200在连接到AP后保存Profile,在CC3200再次启动后,注意不要将所有的Profile删除,否则就无法连接到你之前记录的路由器AP上了,在程序中查找
//! brief This function puts the device in its default state. It:
//! - Set the mode to STATION
//! - Configures connection policy to Auto and AutoSmartConfig
//! - Deletes all the stored profiles  -----------------------------------------------------------这个地方不要打开,否则会删除所有的Profile
//! - Enables DHCP
//! - Disables Scan policy
//! - Sets Tx power to maximum
//! - Sets power policy to normal
//! - Unregister mDNS services
//! - Remove all filters
//! param none
//! return On success, zero is returned. On error, negative is returned
static long ConfigureSimpleLinkToDefaultState()
SlVersionFull ver = [0];
_WlanRxFilterOperationCommandBuff_t RxFilterIdMask = [0];
unsigned char ucVal = 1;
unsigned char ucConfigOpt = 0;
unsigned char ucConfigLen = 0;
unsigned char ucPower = 0;
long lRetVal = -1;
long lMode = -1;
lMode = sl_Start(0, 0, 0);
ASSERT_ON_ERROR(lMode);
// If the device is not in station-mode, try configuring it in station-mode
if (ROLE_STA != lMode)
if (ROLE_AP == lMode)
// If the device is in AP mode, we need to wait for this event
// before doing anything
while(!IS_IP_ACQUIRED(g_ulStatus))
#ifndef SL_PLATFORM_MULTI_THREADED
_SlNonOsMainLoopTask();
#endif
// Switch to STA role and restart
lRetVal = sl_WlanSetMode(ROLE_STA);
ASSERT_ON_ERROR(lRetVal);
lRetVal = sl_Stop(0xFF);
lRetVal = sl_Start(0, 0, 0);
// Check if the device is in station again
if (ROLE_STA != lRetVal)
// We don't want to proceed if the device is not coming up in STA-mode
return DEVICE_NOT_IN_STATION_MODE;
// Get the device's version-information
ucConfigOpt = SL_DEVICE_GENERAL_VERSION;
ucConfigLen = sizeof(ver);
lRetVal = sl_DevGet(SL_DEVICE_GENERAL_CONFIGURATION, &ucConfigOpt,
&ucConfigLen, (unsigned char *)(&ver));
UART_PRINT("Host Driver Version: %snr",SL_DRIVER_VERSION);
UART_PRINT("Build Version %d.%d.%d.%d.31.%d.%d.%d.%d.%d.%d.%d.%dnr",
ver.NwpVersion[0],ver.NwpVersion[1],ver.NwpVersion[2],ver.NwpVersion[3],
ver.ChipFwAndPhyVersion.FwVersion[0],ver.ChipFwAndPhyVersion.FwVersion[1],
ver.ChipFwAndPhyVersion.FwVersion[2],ver.ChipFwAndPhyVersion.FwVersion[3],
ver.ChipFwAndPhyVersion.PhyVersion[0],ver.ChipFwAndPhyVersion.PhyVersion[1],
ver.ChipFwAndPhyVersion.PhyVersion[2],ver.ChipFwAndPhyVersion.PhyVersion[3]);
// Set connection policy to Auto + SmartConfig
// (Device's default connection policy)
lRetVal = sl_WlanPolicySet(SL_POLICY_CONNECTION,
SL_CONNECTION_POLICY(1, 0, 0, 0, 1), NULL, 0);
// Remove all profiles
lRetVal = sl_WlanProfileDel(0xFF);------------------------------------------------------------------不要删除所有的Profile
// Device in station-mode. Disconnect previous connection if any
// The function returns 0 if 'Disconnected done', negative number if already
// disconnected Wait for 'disconnection' event if 0 is returned, Ignore
// other return-codes
lRetVal = sl_WlanDisconnect(); //会把标志位置位,中断是在后面发生的!在后面清除标志位
if(0 == lRetVal)
// Wait
while(IS_CONNECTED(g_ulStatus))
#endif
// Enable DHCP client
lRetVal = sl_NetCfgSet(SL_IPV4_STA_P2P_CL_DHCP_ENABLE,1,1,&ucVal);
// Disable scan
ucConfigOpt = SL_SCAN_POLICY(0);
lRetVal = sl_WlanPolicySet(SL_POLICY_SCAN , ucConfigOpt, NULL, 0);
// Set Tx power level for station mode
// Number between 0-15, as dB offset from max power - 0 will set max power
ucPower = 0;
lRetVal = sl_WlanSet(SL_WLAN_CFG_GENERAL_PARAM_ID,
WLAN_GENERAL_PARAM_OPT_STA_TX_POWER, 1, (unsigned char *)&ucPower);
//add
//lRetVal = sl_WlanPolicySet(SL_POLICY_CONNECTION , SL_CONNECTION_POLICY(1,1,0,0,0), 0, 0);
// Set PM policy to normal
lRetVal = sl_WlanPolicySet(SL_POLICY_PM , SL_NORMAL_POLICY, NULL, 0);
// Unregister mDNS services
lRetVal = sl_NetAppMDNSUnRegisterService(0, 0);
// Remove all 64 filters (8*8)
memset(RxFilterIdMask.FilterIdMask, 0xFF, 8);
lRetVal = sl_WlanRxFilterSet(SL_REMOVE_RX_FILTER, (_u8 *)&RxFilterIdMask,
sizeof(_WlanRxFilterOperationCommandBuff_t));
lRetVal = sl_Stop(SL_STOP_TIMEOUT);
InitializeAppVariables();
return lRetVal; // Success
