TI论坛
张忠雨
7年用户 134经验值
请问AM335X USB0如何使用host模式?
您好,AM335X u***0设置host模式,软件部分是不是只是在这个地方修改就行了,我的内核版本3.2
static struct omap_mu***_board_data mu***_board_data = [
.interface_type = MUSB_INTERFACE_ULPI,
* mode[0:3] = USB0PORT's mode
* mode[4:7] = USB1PORT's mode
* AM335X beta EVM has USB0 in OTG mode and USB1 in host mode.
.mode = (MUSB_HOST << 4) | MUSB_HOST,
.power = 500,
.instances = 1,
回帖(6)
罗兰君
2018-6-21 06:24:58
是的,同时也请检查硬件连接部分。
张忠雨
2018-6-21 06:33:14
引用: 344868615qq 发表于 2018-6-21 06:24
是的,同时也请检查硬件连接部分。
请问一下3.2的内核中能否集成USB网络驱动 CDC MBIM接口功能
张忠雨
2018-6-21 06:49:58
您好,请问下我的USB1也是用HOST模式,内核启动打印有关USB的信息如下
u***core: registered new interface driver u***fs
u***core: registered new interface driver hub
u***core: registered new device driver u***
mu***-ti81xx mu***-ti81xx: mu***0, board_mode=0x11, plat_mode=0x1
mu***-ti81xx mu***-ti81xx: mu***1, board_mode=0x11, plat_mode=0x1
mu***-hdrc: version 6.0, ?dma?, otg (peripheral+host)
mu***-hdrc mu***-hdrc.0: dma type: pio
mu***-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
mu***-hdrc: MHDRC RTL version 2.0
mu***-hdrc: setup fifo_mode 4
mu***-hdrc: 28/31 max ep, 16384/16384 memory
mu***-hdrc mu***-hdrc.0: MUSB HDRC host driver
drivers/u***/core/inode.c: creating file 'devices'
drivers/u***/core/inode.c: creating file '001'
mu***-hdrc mu***-hdrc.0: new USB bus registered, assigned bus number 1
u*** u***1: default language 0x0409
u*** u***1: udev 1, busnum 1, minor = 0
u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002
u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
u*** u***1: Product: MUSB HDRC host driver
u*** u***1: Manufacturer: Linux 3.2.0-EmbedSky mu***-hcd
u*** u***1: SerialNumber: mu***-hdrc.0
u*** u***1: u***_probe_device
u*** u***1: configuration #1 chosen from 1 choice
u*** u***1: adding 1-0:1.0 (config #1, interface 0)
hub 1-0:1.0: u***_probe_interface
hub 1-0:1.0: u***_probe_interface - got id
mu***-hdrc mu***-hdrc.0: USB Host mode controller at e081c000 using PIO, IRQ 18
mu***-hdrc mu***-hdrc.1: dma type: pio
mu***-hdrc mu***-hdrc.1: MUSB HDRC host driver
drivers/u***/core/inode.c: creating file '002'
mu***-hdrc mu***-hdrc.1: new USB bus registered, assigned bus number 2
u*** u***2: default language 0x0409
u*** u***2: udev 1, busnum 2, minor = 128
u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002
u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
u*** u***2: Product: MUSB HDRC host driver
u*** u***2: Manufacturer: Linux 3.2.0-EmbedSky mu***-hcd
u*** u***2: SerialNumber: mu***-hdrc.1
u*** u***2: u***_probe_device
u*** u***2: configuration #1 chosen from 1 choice
u*** u***2: adding 2-0:1.0 (config #1, interface 0)
hub 2-0:1.0: u***_probe_interface
hub 2-0:1.0: u***_probe_interface - got id
mu***-hdrc mu***-hdrc.1: USB Host mode controller at e081e800 using PIO, IRQ 19
u***core: registered new interface driver zd1201
u***core: registered new interface driver cdc_ether
u***core: registered new interface driver cdc_eem
u***core: registered new interface driver dm9601
u***core: registered new interface driver cdc_subset
u***core: registered new interface driver cdc_ncm
u***core: registered new interface driver cdc_acm
u***core: registered new interface driver u***-storage
u***core: registered new interface driver u***serial
u***core: registered new interface driver u***serial_generic
u***serial: USB Serial Driver core
u***core: registered new interface driver option
u***core: registered new interface driver pl2303
u***core: registered new interface driver u***hid
u***hid: USB HID core driver
lsu***
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
插U盘启动内核,打印信息中没有识别U盘
我的vbus上拉到5v,id脚接地,请问还有别的问题导致U盘上电不识别吗
曹丽娜
2018-6-21 07:06:02
先贴下u***部分的原理图把
        如果我的回答解决了您的问题,请确认答案,谢谢!:)
