`铜箔软连接的生产原材料:铜材采用国际1.T2或和T2M或无氧铜带,带箔厚度在0.05mm~0.5mm之间2.搭接面镀锡或镀银3.产品可根据用户要求加工各种非标软连接4.用户可带料加工,搭口尽寸:长220mm,宽440mm,厚40mm总长度不限
Raw materials for copper foil soft connection: international use of copper1.T2 or T2M or oxygen free copper strip, with foil thickness between 0.05mm~0.5mm.2. lap surface tin or silver plating3. products can process various kinds of non-standard soft connections according to user's requirements.4. users can take materials processing, take the mouth as long as Cun: long 220mm, wide 440mm, thick 40mm, unlimited length.
