TI论坛
李淑英
7年用户 222经验值
希望做一个zigbee mesh网络智能家居产品,请问是用Z-Stack Mesh 1.0.0? 还是用zigbee3.0配置mesh 方式?
请问z-stack zigbee3.0  和 Z-Stack Mesh 1.0.0是什么关系?
是否 zigbee3.0 已经包含支持 协调器,路由器,终端设备 mesh 组网功能? 还是需要另一个专用的 Z-Stack Mesh 1.0.0 版本?
希望做一个zigbee mesh 网络智能家居产品是用 Z-Stack Mesh 1.0.0 ? 还是用 zigbee3.0 配置mesh 方式?
回帖(3)
韦明
2018-5-22 07:15:53
官方对两者的介绍如下
Z-Stack Mesh
The new Z-Stack Mesh software is a ZigBee PRO 2012 compliant and certified protocol stack that simplifies the development of standards-based ZigBee mesh products for CC2538 SOCs.
Z-Stack Mesh notables include:
  • Self-healing, robust and proven network stack capable of connecting over 400 nodes
  • Compatible with many-to-many or many-to-one application routing
  • Includes secure over-the-air software download capability for easy in-field updates
  • Compact solution that can be run either in a Wireless Network Processor or Wireless Microntroller (MCU) configuration with the SimpleLink ZigBee CC2530, CC2531 or CC2538enabling flexible host processor options and a variety of memory configurations.
  • Incorporated support for the CC2592 and CC2590 RF front ends which support respectively +22 dBm and +14 dBm transmit power and provide improved receive sensitivity
Get Z-Stack Mesh by clicking on the Download button above.
Z-Stack 3.0
Z-Stack 3.0 is TI's ZigBee 3.0 compliant protocol stack for the CC2530, CC2531, and CC2538System-on-Chip.
  • Based on ZigBee PRO 2015 and Base Device Behavior specifications, with enhanced security and new, application-agnostic device commissioning methods
  • Incorporated support for the CC2592 and CC2590 RF front ends which support +22dBm and +14dBm transmit power, respectively, and provide improved receiver sensitivity
  • Z-Stack 3.0 combines multiple previous ZigBee profiles into one unified standard
    • Unifies multiple previous application profiles into a single profile, providing an interoperable ecosystem for every device type
    • Base Device Behavior defines a common set of mechanisms for network commissioning to be used by all devices
    • ZigBee PRO 2015 provides new and improved security modes, including Install Codes for out-of-band key exchange, and Distributed Security Networks for Coordinator-less network topology
    • Every ZigBee 3.0 routing device will support Green Power Proxy, allowing energy-harvesting and ultra-low power devices to connect seamlessly
    • Forwards and backwards compatibility with previous ZigBee PRO application profiles is maintained
    • Sample Applications included for quick prototyping
    • Over-the-air firmware upgrade, allowing for future updates of deployed systems
    • Compatible with TI's Z-Stack Linux Gateway
    应该3.0是最新的协议。Mesh是以前的,一直没更新。
  • 举报
    李淑英
    2018-5-22 07:22:49
    引用: ljmlvmd 发表于 2018-5-22 07:15
    官方对两者的介绍如下
    Z-Stack Mesh
    谢谢 回复
    看起来 zigbee3.0 可以包含和支持 mesh 组网。
    张秀芳
    2018-5-22 07:42:08
    引用: 胡bbs 发表于 2018-5-22 07:22
    谢谢 回复
    楼主,具体的在zigbee3.0中如何使用mesh呢?是否研究有所进展?
